Top-N
Function
Top-N queries ask for the N smallest or largest values ordered by columns. Both smallest and largest values sets are considered Top-N queries. Top-N queries are useful when you need to display only the N highest or lowest records from a batch/streaming table based on a specific condition.
Syntax Format
1 2 3 4 5 6 7 |
SELECT [column_list] FROM ( SELECT [column_list], ROW_NUMBER() OVER ([PARTITION BY col1[, col2...]] ORDER BY col1 [asc|desc][, col2 [asc|desc]...]) AS rownum FROM table_name) WHERE rownum <= N [AND conditions] |
Syntax Description
- ROW_NUMBER(): Allocates a unique and consecutive number to each line starting from the first line in the current partition. Currently, ROW_NUMBER can be used in the over window function only. RANK() and DENSE_RANK() will be supported soon.
- PARTITION BY col1[, col2...]: Specifies the partition columns. Each partition will have a Top-N result.
- ORDER BY col1 [asc|desc][, col2 [asc|desc]...]: Specifies the ordering columns. The ordering directions can be different for different columns.
- WHERE rownum <= N: Specifies a Top-N query in Flink. Where N represents the N smallest or largest records that need to be returned.
- [AND conditions]: You can add other query conditions in the where clause. Note that the other conditions can only be combined with rownum <= N using the AND logic.
- Top N queries return updated results.
- Flink SQL will sort the input data stream according to the order key.
- So if the top N records have been changed, the changed ones will be sent as retraction/update records to downstream.
- If the top N records need to be stored in external storage, the result table should have the same unique key with the Top-N query.
Example
This is an example to get the top five products per category that have the maximum sales in real time.
1 2 3 4 5 6 |
SELECT * FROM ( SELECT *, ROW_NUMBER() OVER (PARTITION BY category ORDER BY sales DESC) as row_num FROM ShopSales) WHERE row_num <= 5; |
