Updated on 2025-09-05 GMT+08:00
OrderBy & Limit
OrderBy
  • Function
    This function sorts result sets based on one or more columns.
  • Syntax Format
    3
    4
    5
    6
    SELECT [ ALL | DISTINCT ]
      { * | projectItem [, projectItem ]* }
      FROM tableExpression
      [ WHERE booleanExpression ]
      [ GROUP BY { groupItem [, groupItem ]* } ]
      [ ORDER BY Itemtime|Item [ASC | DESC] ]
  • Precautions
    By default, ORDER BY sorts data in ascending order. ASC: indicates the ascending order, and DESC the descending order.
  • Example
    Sort data in ascending order on the time attribute.
    3
    SELECT *
    FROM Orders
    ORDER BY orderTime;
Limit
  • Function
    This clause is used to constrain the number of rows returned.
  • Precautions
    This clause is used in conjunction with ORDER BY to ensure that the results are deterministic.
  • Example
    3
    4
    SELECT *
    FROM Orders
    ORDER BY orderTime
    LIMIT 3;
