UNION
The GROUP BY clause is a core function in SQL for data grouping and summarization. It is mainly used to group rows that have identical values in one or more columns and then apply an aggregate function (such as SUM(), COUNT(), AVG(), MAX(), or MIN()) to each group for calculating summary information.
Column-Based GROUP BY
- Function
This clause is used to group a table based on columns.
- Syntax Format
1 2 3 4
SELECT [ ALL | DISTINCT ] { * | projectItem [, projectItem ]* } FROM tableExpression [ WHERE booleanExpression ] [ GROUP BY { groupItem [, groupItem ]* } ]
- Syntax Description
Column-based GROUP BY can be categorized into single-column GROUP BY and multi-column GROUP BY.
- Single-column GROUP BY indicates that the GROUP BY clause contains only one column.
- Multi-column GROUP BY indicates that the GROUP BY clause contains multiple columns. The table will be grouped according to all fields in the GROUP BY clause. The records whose fields are the same are grouped into one group.
- Precautions
GroupBy generates update results in the stream processing table.
- Example
Group the student table according to the score and name fields and return the grouping results.
1 2
SELECT name,score, max(score) FROM student GROUP BY name,score;
Expression-Based GROUP BY
- Function
This clause is used to group streams according to expressions.
- Syntax Format
1 2 3 4
groupItem can have one or more fields. The fields can be called by string functions, but cannot be called by aggregate functions.
- Precautions
None
- Example
Use the substring function to obtain the character string from the name field, group the student table according to the obtained character string, and return each sub character string and the number of records.
1 2
SELECT substring(name,6),count(name) FROM student GROUP BY substring(name,6);
GROUP BY Using HAVING
- Function
This clause filters a table after grouping it using the HAVING clause.
- Syntax Format
1 2 3 4 5
SELECT [ ALL | DISTINCT ] { * | projectItem [, projectItem ]* } FROM tableExpression [ WHERE booleanExpression ] [ GROUP BY { groupItem [, groupItem ]* } ] [ HAVING booleanExpression ]
Generally, HAVING and GROUP BY are used together. You can use GROUP BY for grouping and the HAVING for filtering.
- Precautions
- If the filtering condition is subject to the results of GROUP BY, the HAVING clause, rather than the WHERE clause, must be used for search. HAVING and GROUP BY are used together. Use GROUP BY for grouping and HAVING for filtering.
- Fields used in HAVING, except for those used for aggregate functions, must exist in GROUP BY.
- The HAVING clause supports arithmetic operations and aggregate functions.
- Example
Group the transactions by num, use the HAVING clause to search for the records in which the maximum value derived from multiplying price with amount is higher than 5000, and return the filtered results.
1 2 3 4
SELECT num, max(price*amount) FROM transactions WHERE time > '2016-06-01' GROUP BY num HAVING max(price*amount)>5000;
