Updated on 2025-09-30 GMT+08:00
Functions
Mathematics Functions
Table 1 Mathematics functions
Function
Purpose
Example Value
abs
Absolute value
abs(number T) -> T
SELECT abs(0.5) LIMIT 1
add
Addition
add(number T, number) -> T
SELECT add(1, 5) LIMIT 1
cbrt
Cubic root
cbrt(number T) -> T
SELECT cbrt(0.5) LIMIT 1
ceil
Rounded up
ceil(number T) -> T
SELECT ceil(0.5) LIMIT 1
divide
Division
divide(number T, number) -> T
SELECT divide(1, 0.5) LIMIT 1
e
Natural base number e
e() -> double
SELECT e() LIMIT 1
exp
Power of the natural base number e
exp(number T) -> T
SELECT exp(0.5) LIMIT 1
expm1
Subtract one from the power of the natural base number e.
expm1(number T) -> T
SELECT expm1(0.5) LIMIT 1
floor
Rounded down
floor(number T) -> T
SELECT floor(0.5) AS Rounded_Down LIMIT 1
ln
Returns the natural logarithm.
ln(number T) -> double
SELECT ln(10) LIMIT 1
log
Logarithm with T as the base
log(number T, number) -> double
SELECT log(10) LIMIT 1
log2
Logarithm with 2 as the base
log2(number T) -> double
SELECT log2(10) LIMIT 1
log10
Logarithm to base 10
log10(number T) -> double
SELECT log10(10) LIMIT 1
modulus
Remainder
modulus(number T, number) -> T
SELECT modulus(2, 3) LIMIT 1
multiply
Multiplication
multiply(number T, number) -> number
SELECT multiply(2, 3) LIMIT 1
pi
π
pi() -> double
SELECT pi() LIMIT 1
pow
T power of
pow(number T, number) -> T
SELECT pow(2, 3) LIMIT 1
power
T power of
power(number T) -> T, power(number T, number) -> T
SELECT power(2, 3) LIMIT 1
rand
Random number.
rand() -> number, rand(number T) -> T
SELECT rand(5) LIMIT 1
rint
Discard decimals.
rint(number T) -> T
SELECT rint(1.5) LIMIT 1
round
Round off
round(number T) -> T
SELECT round(1.5) LIMIT 1
sign
Symbol
sign(number T) -> T
SELECT sign(1.5) LIMIT 1
signum
Symbol
signum(number T) -> T
SELECT signum(0.5) LIMIT 1
sqrt
Square root
sqrt(number T) -> T
SELECT sqrt(0.5) LIMIT 1
subtract
Subtraction
subtract(number T, number) -> T
SELECT subtract(3, 2) LIMIT 1
Division
number / number -> number
SELECT 1 / 100 LIMIT 1
Remainder
number % number -> number
SELECT 1 % 100 LIMIT 1
Trigonometric Functions
Table 2 Trigonometric functions
Functions
Purpose
Example Value
acos
Arc cosine
acos(number T) -> double
SELECT acos(0.5) LIMIT 1
asin
Arc sine
asin(number T) -> double
SELECT asin(0.5) LIMIT 1
atan
Inverse tangent
atan(number T) -> double
SELECT atan(0.5) LIMIT 1
atan2
T Arc tangent of the result of dividing U
atan2(number T, number U) -> double
SELECT atan2(1, 0.5) LIMIT 1
cos
Cosine
SELECT cos(0.5) LIMIT 1
cosh
hyperbolic cosine
cosh(number T) -> double
SELECT cosh(0.5) LIMIT 1
cot
Cotangent
cot(number T) -> double
SELECT cot(0.5) LIMIT 1
degrees
Converting radians into degrees
degrees(number T) -> double
SELECT degrees(0.5) LIMIT 1
radians
Converting degrees into radians
radians(number T) -> double
SELECT radians(0.5) LIMIT 1
sin
Sine
SELECT sin(0.5) LIMIT 1
sinh
hyperbolic sine
sinh(number T) -> double
SELECT sinh(0.5) LIMIT 1
tan
Tangent
SELECT tan(0.5) LIMIT 1
Temporal Functions
Table 3 Temporal functions
Function
Purpose
Example Value
curdate
Specifies the current date.
curdate() -> date
SELECT curdate() LIMIT 1
date
Date
date(date) -> date
SELECT date() LIMIT 1
date_format
Obtains the date value based on the format.
date_format(date, string) -> string
SELECT date_format(date, 'Y') LIMIT 1
day_of_month
Month
day_of_month(date) -> integer
SELECT day_of_month(date) LIMIT 1
day_of_week
Day of a week
day_of_week(date) -> integer
SELECT day_of_week(date) LIMIT 1
day_of_year
Number of days in the current year
day_of_year(date) -> integer
SELECT day_of_year(date) LIMIT 1
hour_of_day
Number of hours on the current day
hour_of_day(date) -> integer
SELECT hour_of_day(date) LIMIT 1
maketime
Date of Generation
maketime(integer, integer, integer) -> time
SELECT maketime(11, 30, 00) LIMIT 1
minute_of_hour
Number of minutes in the current hour
minute_of_hour(date) -> integer
SELECT minute_of_hour(date) LIMIT 1
minute_of_day
Number of minutes on the current day
minute_of_day(date) -> integer
SELECT minute_of_day(date) LIMIT 1
monthname
Month Name
monthname(date) -> string
SELECT monthname(date) LIMIT 1
now
Current time.
now() -> time
SELECT now() LIMIT 1
second_of_minute
Number of seconds
second_of_minute(date) -> integer
SELECT second_of_minute(date) LIMIT 1
timestamp
Date
timestamp(date) -> date
SELECT timestamp(date) LIMIT 1
year
Year
SELECT year(date) LIMIT 1
Text Functions
Table 4 Text functions
Function
Purpose
Example Value
ascii
ASCII value of the first character
ascii(string T) -> integer
SELECT ascii('t') LIMIT 1
concat_ws
Connection String
concat_ws(separator, string, string) -> string
SELECT concat_ws('-', 'Tutorial', 'is', 'fun!') LIMIT 1
left
Obtain a character string from left to right.
left(string T, integer) -> T
SELECT left('hello', 2) LIMIT 1
length
length
length(string) -> integer
SELECT length('hello') LIMIT 1
locate
Search for a string
locate(string, string) -> integer
SELECT locate('o', 'hello') LIMIT 1
replace
Replace strings
replace(string T, string, string) -> T
SELECT replace('hello', 'l', 'x') LIMIT 1
right
Obtain a character string from right to left.
right(string T, integer) -> T
SELECT right('hello', 1) LIMIT 1
rtrim
Remove the empty character string on the right.
rtrim(string T) -> T
SELECT rtrim('hello ') LIMIT 1
substring
Obtaining a Substring
substring(string T, integer, integer) -> T
SELECT substring('hello', 2,5) LIMIT 1
trim
Remove empty character strings on both sides.
trim(string T) -> T
SELECT trim(' hello ') LIMIT 1
upper
Convert all letters into uppercase letters.
upper(string T) -> T
SELECT upper('helloworld') LIMIT 1
Other
Table 5 Other
Function
Purpose
Example Value
if
if condition
if(boolean, object, object) -> object
SELECT if(false, 0, 1) LIMIT 1 ,
SELECT if(true, 0, 1) LIMIT 1
ifnull
If the field is null, the default value is used.
ifnull(object, object) -> object
SELECT ifnull('hello', 1) LIMIT 1 ,
SELECT ifnull(null, 1) LIMIT 1
isnull
Indicates whether a field is null. If yes, 1 is returned. If no, 0 is returned.
isnull(object) -> integer
SELECT isnull(null) LIMIT 1 ,
SELECT isnull(1) LIMIT 1
