SELECT
Syntax of Analysis Statements
The syntax of a complete analysis statement is as follows:
1 2 3 4 | SELECT [DISTINCT] (* | expression) [AS alias] [, ...] [GROUP BY expression [, ...] [HAVING predicates]] [ORDER BY expression [ASC | DESC] [, ...]] [LIMIT size OFFSET offset] |
SELECT indicates the field to be queried. The following part describes parameters and examples for the SELECT syntax.
Using * to Query All Fields
Use * to query all fields.
1 | * |SELECT * |
| account_number | firstname | gender | city | balance | employer | state | lastname | age |
| 1 | Amber | M | Brogan | 39225 | Pyrami | IL | Duke | 32 |
| 16 | Hattie | M | Dante | 5686 | Netagy | TN | Bond | 36 |
| 13 | Nanette | F | Nogal | 32838 | Quility | VA | Bates | 28 |
| 18 | Dale | M | Orick | 4180 | null | MD | Adams | 32 |
Querying Specified Fields
Query the specified fields firstname and lastname.
1 | * |SELECT firstname, lastname |
| firstname | lastname |
| Amber | Duke |
| Hattie | Bond |
| Nanette | Bates |
| Dale | Adams |
Using AS to Define Field Aliases
Use AS to define an alias for a field, renaming account_number to num.
1 | * |SELECT account_number AS num |
| num |
| 1 |
| 16 |
| 13 |
| 18 |
Using the DISTINCT Statement
Use DISTINCT to remove duplicate values from the age field.
1 | * |SELECT DISTINCT age |
| age |
| 32 |
| 36 |
| 28 |
Using SQL Functions
Use a SQL function to check the length of the firstname field. For details about functions, see Function.
1 | * |SELECT LENGTH(firstname) as len, firstname |
| len | firstname |
| 4 | Amber |
| 6 | Hattie |
| 7 | Nanette |
| 4 | Dale |
