Updated on 2026-05-15 GMT+08:00
Query Statements
A query statement is used to specify the filter criteria for log query and return the logs that meet the filter criteria. By setting filter criteria, you can quickly query required logs.
This topic describes query statements and examples.
Syntax
A query statement can be in either of the following formats:
  • If the value is only *, full data is returned without filtering.
  • It consists of one or more query clauses. The clauses are connected by NOT, AND, and OR. () can be used to increase the priority of the query conditions in parentheses.
The basic structure of a query clause is as follows:
Field Name Operator Field Value
Operators lists the operators that can be used.
Operators
Table 1 Operator descriptions
Operator
Queries logs in which the value of a field is equal to a certain value.
Queries the logs in which the value of a field is not equal to a certain value.
Queries logs in which the value of a field is greater than a specified value.
Queries logs in which the value of a field is less than a specified value.
Queries logs in which the value of a field is greater than or equal to a specified value.
Queries logs in which the value of a field is less than or equal to a specified value.
IN
Queries the logs whose field values are within a specified value range.
BETWEEN
Queries the logs whose field values are in the specified range.
LIKE
Searches for logs of a field value in full text.
IS NULL
Queries logs whose field value is NULL.
IS NOT NULL
Queries logs with the value of a specific field set to NOT NULL.
Query Statements
Table 2 Example query statements
Query Requirement
Query Statement
All logs
Logs about successful GET requests (status codes 200 to 299).
request_method = 'GET' AND status BETWEEN 200 AND 299
Logs of GET or POST requests
request_method = 'GET' OR request_method = 'POST'
Logs of non-GET requests
NOT request_method = 'GET'
Logs about successful GET or POST requests
(request_method = 'GET' OR request_method = 'POST') AND status BETWEEN 200 AND 299
Logs of GET or POST request failures
(request_method = 'GET' OR request_method = 'POST') NOT status BETWEEN 200 AND 299
Logs of successful GET requests (status code: 200 to 299) whose request time is greater than or equal to 60 seconds.
request_method = 'GET' AND status BETWEEN 200 AND 299 AND request_time >= 60
Logs whose request time is 60 seconds.
request_time = 60
Example Query Statements
The following is an example of data selected from the i_sec_hss_log table. The data is for reference only.
Table 3 Example
__time
hostName
hostUuid
hostIp
region
ipList
2025-07-12T14:38:27.764+08:00
HCSS-ECS-8253
bf9d44b0-45e2-46a3-9d23-c9965051abb6
100.64.129.14
cn-north-7
192.168.12.58
2025-07-12T20:38:54.025+08:00
ecs-574a
827e17d7-4443-4d6e-9dff-7c10f29efa74
10.75.197.134
cn-north-7
172.17.0.1,192.168.0.77
ecs-574a
10.75.197.134
cn-north-7
2025-07-12T14:38:55.356+08:00
hcss_ecs_3924
c4c5ee97-b82e-443a-b0b5-cd897a5488d8
10.75.196.207
cn-north-7
192.168.4.168
hcss_ecs_3924
10.75.196.207
cn-north-7
192.168.4.168
hcss_ecs_3924
10.75.196.207
cn-north-7
192.168.4.168
hcss_ecs_3924
10.75.196.207
cn-north-7
192.168.4.168
2025-07-12T14:38:59.248+08:00
HCSS-ECS-8253
100.64.129.14
cn-north-7
192.168.12.58
2025-07-12T14:39:31.747+08:00
HCSS-ECS-8253
100.64.129.14
cn-north-7
192.168.12.58
2025-07-12T14:40:03.233+08:00
HCSS-ECS-8253
100.64.129.14
cn-north-7
192.168.12.58
2025-07-12T14:40:35.735+08:00
HCSS-ECS-8253
100.64.129.14
cn-north-7
192.168.12.58
2025-07-12T20:40:57.086+08:00
ecs-574a
10.75.197.134
cn-north-7
Example: Query the host whose IP address is 192.168.12.58.
ipList = '192.168.12.58'
Table 4 Query result examples
__time
hostName
hostUuid
hostIp
region
ipList
HCSS-ECS-8253
100.64.129.14
cn-north-7
192.168.12.58
HCSS-ECS-8253
100.64.129.14
cn-north-7
192.168.12.58
HCSS-ECS-8253
100.64.129.14
cn-north-7
192.168.12.58
HCSS-ECS-8253
100.64.129.14
cn-north-7
192.168.12.58
HCSS-ECS-8253
100.64.129.14
cn-north-7
192.168.12.58
