Starting an Immediate Baseline Check
To learn about the latest status of the cloud service baseline configurations, execute or let SecMaster execute a check plan. Then you can view which configurations are unsafe in the check results. The baseline inspection supports periodic and immediate checks.
- Periodic check: SecMaster periodically executes the default check plan or the check plans you configure.
- Immediate check: You can start check items in all security standards or a specific check plan anytime.
This topic describes how to start an immediate baseline inspection. You can select the following check types:
- Immediate Check on All Compliance Packs: Check the compliance of all automatic check items in in-use compliance packs.
- Starting a Check Based on a Check Plan: Check the compliance of the check items in the compliance pack configured in a selected check plan.
- Immediate Checks for Certain Check Items: check the selected check items.
During a baseline check, some check items in the Huawei Cloud Security Configuration 3.0 compliance pack and all check items in the ISO/IEC 27002:2022 compliance pack rely on automatic alert conversion of SecMaster compliance baseline logs and Config audit baseline logs.
- Enabling the Config resource recorder: If the baseline check scope includes all check items in the ISO/IEC 27002:2022 compliance pack and some check items in the Huawei Cloud Security Configuration 3.0 compliance pack, you must enable the Config resource recorder on the Config console.
- If the baseline check scope specifies certain accounts and only the current account is included, enable the Config resource recorder by referring to Configuring the Resource Recorder.
- If the baseline check scope matches any of the following scenarios, enable the Config resource recorder by referring to Batch Configuring the Resource Recorder.
- Scenario 1: The check scope includes all accounts.
- Scenario 2: The check scope specifies certain accounts, and those accounts include one or more accounts other than the current account.
- Scenario 3: The check scope specifies certain accounts, and those accounts include both the current account and other accounts.
- Cloud service access: If the baseline check includes all check items in the ISO/IEC 27002:2022 compliance pack and some check items in the Huawei Cloud Security Configuration 3.0 compliance pack, you need to integrate the following logs in SecMaster and enable automatic alert conversion:
- Enable automatic alert conversion for compliance baseline logs in SecMaster. For details, see Enabling Log Access.
- Enable automatic alert conversion for audit baseline logs in Config. For details, see Enabling Log Access.
Notes and Constraints
- An immediate check task can be executed only once within 10 minutes.
- A periodic check can be manually started only once within 10 minutes.
- You can set auto check items in Cloud Security Compliance Check 1.0, Network Security, and Huawei Cloud Security Configuration 3.0 compliance packs. For check items that support only manual checks, SecMaster generates check items whose check results are To be checked. For those check items, you need to perform a manual check offline and then report the check results to the SecMaster console.
Basic Concepts
- Operation accounts: An operations account, or parent account, is an account that can manage member accounts. An operations account can manage multiple service accounts.
- Service account: A service account is a member account, or child account, managed by an operations account. A service account (child account) can be managed by only one operations account.
- Primary workspace: The first workspace created by SecMaster is the primary workspace by default. The workspace is pinned on top of the page. You can also change the primary workspace. On the page, click
next to the target workspace. On the workspace details page displayed, toggle on Primary workspace.
This part describes how to start an immediate check for automatic check items in in-use compliance packs.
- Log in to the SecMaster console.
- Click
in the upper left corner of the management console and select a region or project. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace. Figure 1 Workspace management page
- In the navigation pane on the left, choose Risk Prevention > Baseline Inspection. Figure 2 Accessing the check result page
- On the Check Result tab, click Check Now. In the dialog box displayed, click OK.
Refresh the page. To check whether the displayed result is the latest, click View Details in the Operation column and check the time in Latest Check.
- Only the operation account of the primary workspace can set the account range for baseline inspection. The procedure is as follows:
- On the Check Result page, click Check Now and select Scan Scope. The scan scope is the account for the baseline inspection.
- All accounts: If you select All accounts, the baseline inspection is performed for the operation account and all service accounts managed by the operation account.
- Specify account: If you select Specify account and select some accounts, the check plan is applied to the selected service accounts managed by the operation account.
- Click OK.
- Refresh the page. To check whether the displayed result is the latest, click View Details in the Operation column and check the time in Latest Check.
If the workspace is not the primary workspace or the account is not an operations account, you cannot set the account range for baseline inspection. To start a check, you only need to click Check Now on the Check Result page and click OK in the displayed dialog box. Refresh the page. To check whether the displayed result is the latest, click View Details in the Operation column and check the time in Latest Check.
This part describes how to immediately execute a check plan. Once a check plan is kicked off, SecMaster immediately executes each check item included in compliance packs in the check plan.
- Click
in the upper left corner of the management console and select a region or project. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace. Figure 3 Workspace management page
- In the navigation pane on the left, choose . On the displayed page, click the Security Standards tab. Then, click the Check Plan tab. Figure 4 Accessing the Check Plan tab
- In a check plan box, click Check Now.
SecMaster immediately executes the selected baseline check plan.
This part describes how to start an immediate check on certain check items.
- Click
in the upper left corner of the management console and select a region or project. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace. Figure 5 Workspace management page
- In the navigation pane on the left, choose Risk Prevention > Baseline Inspection. Figure 6 Accessing the check result page
- Check one or more check items immediately.
- Check for a certain check item
- In the check item list in the lower part of the Check Result tab, locate the target automatic check item and click Check Now in the Operation column.
Refresh the page and check the details next to Last checked and ensure that the latest scan result is displayed.
- Checks on some check items
- In the check item list in the lower part of the check result tab, select multiple auto check items and click Check Now in the upper left corner above the check item list.
