Help Center/ SecMaster/ User Guide/ Buying SecMaster/ Purchasing Value-Added Packages
Updated on 2025-01-20 GMT+08:00
In addition to the standard and professional editions, SecMaster also provides value-added features for you to choose. This topic describes how to purchase a value-added package.
If you are stuck due to insufficient permission, refer to Assigning Permissions.
Value-added Package Specifications
Based on the standard and professional editions, SecMaster provides the following functions in the value-added package:
  • Large Screen
    • Function description:
      There are always such scenarios as presentation, reporting, or real-time monitoring where you need to present the analysis results of SecMaster on big screens to achieve better demonstration effect.
    • Purchase configuration description:
      Make a purchase based on your service needs.
  • Log Audit
      It collects varied types of log data and stores the collected data for security analysis. You can set the data collection volume and data retention volume for each day.
      In pay-per-use billing mode, you will be billed based on the actual collection and storage volume. You do not need to configure specifications.
      In yearly/monthly billing mode, you need to specify New Log per day based on your estimations on service requirements. SecMaster will automatically allocate package specifications based on the value you provide. For details about the specifications, see Table 1.
      Table 1 Specifications of the security data collection and retention packages
      Package
      Recommended Configuration for Yearly/Monthly Subscription
      Applicable Range
      Security Data Collection
      The volume of data you expect SecMaster to collect each day.
      Minimum value: 5 GB. You can estimate the volume by multiplying the number of ECSs you have by 120 MB. Maximum volume for each order: 500 GB.
      When you make a purchase, SecMaster auto-fills this parameter based on the new log volume you specify. You do not need to configure this parameter separately.
      5 *1 GB
      0 GB to 5 GB (included)
      5 *2 GB
      5 GB to 10 GB (included)
      5 *3 GB
      10 GB to 15 GB (included)
      The others follow the same rule. A maximum of 500 GB can be purchased through an order.
      Security Data Retention
      The volume of data you expect SecMaster to store.
      The minimum volume is 100 GB. You can estimate the volume by multiplying new log volume per day by seven. The maximum volume for each order is 3,500 GB.
      100 *1 GB
      0 GB to 100 GB (included)
      100 *2 GB
      100 GB to 200 GB (included)
      100 *3 GB
      200 GB to 300 GB (included)
      The others follow the same rule. A maximum of 3,500 GB can be purchased through an order.
      • The quotas of security data retention and security data collection packages can be counted together. However, these packages cannot cover what you used before the purchase. Subscriptions to these packages cannot be cancelled.
      • For yearly/monthly security data collection and retention packages, data volume in excess of the package quotas will be billed on a pay-per-use basis.
      • Pay-per-use resources will not be disabled automatically even if yearly/monthly security data retention and security data collection packages expire. They will always be enabled on a pay-per-use basis.
        For yearly/monthly security data collection package, data volume in excess of the package quota will be billed each day on a pay-per-use basis.
        For example, a user purchases a security data collection package with 5 GB/day/quota for one month. If the user uses 5 GB data collection before 22:00 on the purchase day, and then uses 2 GB data collection 22:00 00 and 24:00, the extra 2 GB will be billed on a pay-per-use basis. Starting from 00:00 on the next day, a 5 GB/day/quota is available to the user again.
  • Security Analysis
      Security analysis is the cloud native security information and event management solution SecMaster provides for you. The solution collects logs, reports alerts, aggregates security data, performs association analysis, and more.
      Table 2 lists the free quota of security analysis. You can increase the quota at an extra cost if needed.
      In pay-per-use billing mode, you will be billed based on the actual volume. You do not need to configure specifications.
      In yearly/monthly billing mode, you need to set the data volume as required. For details, see Table 3.
      Table 2 Specifications for free security analysis quota
      Function
      Standard Edition
      Professional
      Security Analysis
      Security data collection
      120 MB/day/quota
      120 MB/day/quota
      Security data retention
      120 MB/day/quota
      120 MB/day/quota
      Security data export
      120 MB/day/quota
      120 MB/day/quota
      Platform security data
      40 MB/day/quota
      40 MB/day/quota
      Security Modeling Analysis
      120 MB/day/quota
      Table 3 Recommended security analysis configurations
      Value-added Function
      Recommended Quantity for Yearly/Monthly Subscription
      Security Analysis
      You can estimate the security analysis data volume based on 120 MB/ECS/day.
      This estimate volume will be applied to security data collection, security data retention, security data export, platform security data, and security modeling analysis as well. If the quota for security analysis is used up, this function becomes unavailable on that day, but it turns to be available at 00:00 the next day.
      For example, if this parameter is set to 1 GB/day, each day there will be 1 GB of security data that can be collected, 1 GB of security data stored, 1 GB of security data exported, 1 GB of platform security data reported, and 1 GB of data for security modeling analysis.
  • SOC
      Once SecMaster detects a threat, Security Orchestration (SOC) starts automated response orchestration and works with related cloud services to block and isolate threat sources. SOC provides quick and effective security event responses.
      Table 4 lists the free quota of security orchestration. You can increase the quota at an extra cost if needed.
      In pay-per-use billing mode, you will be billed based on the actual security orchestration operation times. You do not need to configure specifications.
      In yearly/monthly billing mode, you need to set the operation times as required. For details, see Table 5.
      Table 4 Specifications for free security orchestration quota
      Function
      Standard Edition
      Professional Edition
      x
      Operations: 7,000
      Table 5 Recommended security orchestration configurations
      SOC
      SecMaster supports 7,000 operations per day for each server. Set this parameter as required.
      If the quota for security orchestration is used up, this function becomes unavailable on that day, but it turns to be available at 00:00 the next day.
Limitations and Constraints
  • The value-added package is an additional payment item for the standard or professional edition. To use the value-added package, you need to purchase the standard or professional edition first.
Buying a Value-Added Package
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the upper left corner of the page and choose Security & Compliance > SecMaster.
  4. In the navigation pane on the left, choose Security Overview, or select Purchased Resources. On the page displayed, click Buy Value-added Pack in the upper right corner.
  5. On the purchase page, configure required parameters.
    Table 6 Parameters for purchasing a value-added package
    Billing Mode
    Select Yearly/Monthly or Pay-per-use billing mode based on your needs.
    • Yearly/Monthly is a prepaid billing mode. You pay in advance for a subscription term. The longer you use the service, the more discounts you got.
    • Pay-per-use billing is a postpaid mode in which you pay for what you use. You are billed by second based on the actual usage. Your bill is settled by the hour. With the pay-per-use billing mode, you can easily adapt to resource requirement changes, reducing the risk of over-provisioning of resources or lacking capacity. In this mode, there are no upfront commitments required.
    Region
    Select your region.
    Configuration
    The configuration of the current SecMaster edition.
    Large Screen
    Log Audit
    When purchasing a yearly/monthly package, you need to estimate the volume of new logs generated each day and specify New Log. SecMaster will automatically specify the security data collection and retention specifications. For details, see Value-added Package Specifications.
    Security Analysis
    If you want to buy a yearly/monthly package, you are advised to estimate the data volume on a basis of 120 MB per day for each server. The data volume you set will be applied to security data collection, security data retention, security data export, platform security data, and security modeling analysis as well.
    SOC
    If you want to buy a yearly/monthly package, set the number of operations as required.
    Tag
    TMS's predefined tag function is recommended for adding the same tag to different cloud resources. You can also create tags when purchasing SecMaster.
    Required Duration
    Select the required duration as required. You do not need to configure this parameter in pay-per-use mode.
    The Auto-renew option enables the system to renew your service by the purchased period when the service is about to expire.
  6. Confirm the product details and click Next.
  7. After confirming that the order details are correct, read the SecMaster Disclaimer, select "I have read and agree to the SecMaster Disclaimer", and click Pay Now.
  8. On the payment page, select a payment method and complete the payment.
Follow-up Operations
  • If the large screen function is about to expire or has expired, go to the Purchased Resources, locate the target resource, and click Renew to extend the validity period. For more details, see Renewing Your Subscriptions.
  • If you no longer need the value-added package, go to the Security Overview page, hover over the edition information in the upper right corner of the page, and click Unsubscribe or Cancel in the displayed pane. For details, see Unsubscribing from SecMaster.
