Viewing a Workbench
The workbench leverages standard security service APIs to let you rapidly build a management UI via flexible drag-and-drop controls. It serves as a unified entry point to access all seven defense layers and offers dedicated operational modules for segmented scenarios, such as AI security posture management platform (AI-SPM) and account risk control. All these enable full lifecycle management within the SecMaster workbench framework.
- System workbenches are the ones built in SecMaster. They are Account Risk Control Workbench and Large Model Safety Workbench.
- Account Risk Control Workbench displays the overall situation of identity security risks through three modules: Access Key Leak, Unsafe Settings of accounts, IAM users, and agencies, and Alerts, helping you quickly identify risks.
- Large Model Safety Workbench displays the compliance situation of AI models in real time. It detects the risk of inference security, corpus security, and environment security in real time to help you identify risks and potential threats of your AI models.
This section describes how to check existing workbenches.
Viewing a Workbench
- Log in to the SecMaster console.
- Click
in the upper left corner of the management console and select a region or project. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace. Figure 1 Workspace management page
- In the navigation pane on the left, choose .
- On the Workbenches page, view the information about existing workbenches. You can check workbenches by Card or Table.
Card: Click Card to display existing workbenches in card format.
Figure 2 Viewing existing workbenches in card format
Table: Click Table to display existing workbenches in table format.
Figure 3 Viewing existing workbenches in table format
- On the Workbenches page, you can search for workbenches by category, status, and keyword.
- Search by type: You can search for workbenches by All categories, System, or Custom. System indicates built-in workbenches, and Custom indicates the workbenches you create.
- Search by status: You can search for workbenches by All release statuses, Released, or Unreleased based on the release status of the workbench.
- Search by name, tag, and creation time.
- Name: Search by the workbench name. Fuzzy search is supported. The name can contain 1 to 64 characters. Only letters, digits, underscores (_), periods (.), and hyphens (-) are allowed.
- Tag: Search by workbench label. system is a workbench type. Scenario workbench and Seven-layer defense workbench are workbench categories. Unreleased is the workbench release status. They are not tags. When searching by tag, you can enter a maximum of 10 tags. You need to use a comma (,) to separate every two tags. Each tag can contain 1 to 64 characters, and only letters, digits, spaces, periods (.), underscores (_), hyphens (-), and ampersands (&) are allowed. Fuzzy search is supported.
- Creation time: Set Start Time and End Time on the page to search for workbenches created within the specified period.
- Search by keyword: You can enter a keyword in the search box, and the system performs fuzzy search based on Name and Description of the workbench and displays the associated workbench information.
