Updated on 2025-11-13 GMT+08:00
Parser Rules
The tenant-side data collection uses custom Logstash collectors for data transmission. Parsers mainly work as codeless filters in Logstash. Currently, the following types of Logstash filter plugins are supported.
Table 1 Supported types
Parser
Plugin in Logstash
Key-Value filter
kv
Parses key-value pairs. For details about parsing rules, see Table 2.
Mutate filter
mutate
Performs general mutations on fields. For details about parsing rules, see Table 3.
Grok filter
grok
Parses regular expressions. For details about parsing rules, see Table 4.
Date filter
date
Parses the date. For details about parsing rules, see Table 5.
Drop filter
drop
Deletes packets. There is no specific rule. If you use this parser, logs received will be deleted.
Prune filter
prune
Parses blacklists and whitelists. For details about parsing rules, see Table 6.
CSV filter
csv
Parses the CSV data. For details about parsing rules, see Table 7.
Function filter
ruby
Executes ruby code. For details about parsing rules, see Table 8.
JSON filter
json
Converts the JSON data. For details about parsing rules, see Table 9.
Split filter
split
Splits data. For details about parsing rules, see Table 10.
Clone filter
clone
Duplicates data. For details about parsing rules, see Table 11.
UUID filter
uuid
Parses UUIDs. For details about parsing rules, see Table 12.
Table 2 Kv filter
Parsing Rule
Logstash Configuration Item
Type
Default Value
Mandatory
Source
source
string
source
Yes
Defines the fields to be translated.
Target
target
string
message
No
Defines the target fields.
Field_split
field_split
string
No
Splits fields.
Value_split
value_split
string
No
Splits fields.
Trim_key
trim_key
string
No
Removes spaces from the key.
Trim_value
trim_value
string
No
Removes spaces from the value.
Allow_duplicate_values
allow_duplicate_values
boolean
true
No
Allows duplicate values.
Default_keys
default_keys
array
No
Adds keys.
Exclude_keys
exclude_keys
array
No
Excludes certain keys.
Include_keys
include_keys
array
No
Includes certain keys.
Prefix
prefix
string
No
Performs prefix matches.
Recursive
recursive
boolean
true
No
Performs Recursive parsing.
Transform_key
transform_key
string
No
Transforms keys.
Add_field
add_field
hash
No
Adds fields.
add_tag
add_tag
array
No
Adds tags.
Remove_field
remove_field
array
No
Removes fields.
Remove_tag
remove_tag
array
No
Removes tags.
Id
id
string
No
ID.
Whitespace
whitespace
string
strict/lenient
No
Allows whitespace characters.
Remove_char_key
remove_char_key
string
No
Removes characters from the key.
Table 3 Mutate filter
Parsing Rule
Type
Default Value
Mandatory
Convert
convert
hash
No
Converts a field's value into a different type.
Join
join
hash
No
Joins arrays.
Lowercase
lowercase
array
No
Converts characters into its lowercase equivalent.
Coerce
coerce
hash
No
Sets the default value of a field.
Rename
rename
hash
No
Renames fields.
Replace
replace
hash
No
Replaces the value of a field with a new value.
Split
split
hash
No
Split a field to an array.
Strip
strip
array
No
Strips spaces from fields.
Update
update
hash
No
Updates fields.
Uppercase
uppercase
array
No
Converts characters into their uppercase equivalent.
Add_field
add_field
hash
No
Adds fields.
Add_tag
add_tag
array
No
Adds tags.
Remove_field
remove_field
array
No
Removes fields.
Remove_tag
remove_tag
array
No
Removes tags.
ID
id
string
No
Id
Copy
copy
hash
No
Copies fields.
Gsub
gsub
array
No
Replaces the gsub value.
Table 4 Grok filter
Parsing Rule
Type
Default Value
Mandatory
match
match
hash
Yes
Performs regex matches.
Break_on_match
break_on_match
boolean
true
No
Breaks on the first match.
Overwrite
overwrite
array
message
No
Overwrites fields.
Add_field
add_field
hash
No
Adds fields.
Add_tag
add_tag
array
No
Adds tags.
Remove_field
remove_field
array
No
Removes fields.
Remove_tag
remove_tag
array
No
Removes tags.
Id
id
string
No
Id
Table 5 Date filter
Parsing Rule
Type
Default Value
Mandatory
Match
match
array
Yes
Performs regex match.
Target
target
string
timestamp
Yes
Target fields.
Add_field
add_field
hash
No
Adds fields.
Add_tag
add_tag
array
No
Adds tags.
Remove_field
remove_field
array
No
Removes fields.
Remove_tag
remove_tag
array
No
Removes tags.
Id
id
string
test
No
Id
Locale
locale
string
No
Locale
Timezone
Specifies the time zone.
string
+8:00
No
Table 6 Prune filter
Parsing Rule
Type
Default Value
Mandatory
Blacklist_names
blacklist_names
array
No
Excludes fields whose names match specified regular expressions.
Blacklist_values
blacklist_values
array
No
Excludes specified fields if their values match one of the supplied regular expressions.
Whitelist_names
whitelist_names
array
No
Includes specified fields only if their names match specified regular expressions.
Whitelist_values
whitelist_values
array
No
Includes specified fields only if their values match one of the supplied regular expressions.
Table 7 CSV filter
Parsing Rule
Type
Default Value
Mandatory
Source
source
string
message
No
Defines the fields to be parsed.
Columns
columns
array
No
Defines a list of column names.
Separator
separator
string
No
Defines the column separator value.
Skip_empty_columns
skip_empty_columns
boolean
true
No
Defines whether empty columns can be skipped.
Table 8 Function filter
Parsing Rule
Type
Default Value
Mandatory
Filter_length
filter_length
number
10
No
Controls the field length.
Set_time
set_time
ruby_time
123
No
Sets a time.
Table 9 JSON filter
Parsing Rule
Type
Default Value
Mandatory
Source
source
string
message
Yes
Defines source fields.
Skip_on_invalid_json
skip_on_invalid_json
boolean
true
No
Skips invalid json fields.
Add_field
add_field
hash
null
No
Adds fields.
Add_tag
add_tag
array
null
No
Adds tags.
Remove_field
remove_field
array
null
No
Removes fields.
Remove_tag
remove_tag
array
null
No
Removes tags.
Target
target
string
message
No
Defines target fields.
Table 10 Split filter
Parsing Rule
Type
Default Value
Mandatory
Field
field
string
message
Yes
Defines fields to be split.
Table 11 Clone filter
Parsing Rule
Type
Default Value
Mandatory
Clone
clones
array
Yes
Defines the list of fields to be cloned.
Table 12 UUID filter
Parsing Rule
Type
Default Value
Mandatory
Target
target
string
uuid
Yes
Target fields.
Overwrite
overwrite
boolean
true
Yes
Defines whether to overwrite.
