Updated on 2025-08-11 GMT+08:00
Managing Workspace Tags
After creating a workspace, you can add, edit, and delete tags configured for the workspace. A tag consists of a key-value pair. Tags are used to identify, and classify workspaces. Workspace tags are used for workspace management only.
This topic describes how to manage tags.
Limitations and Constraints
A maximum of 20 tags can be added for a workspace.
  1. Log in to the SecMaster console.
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the upper left corner of the page and choose Security & Compliance > SecMaster.
  4. In the navigation pane on the left, choose Workspaces > Management.
    Figure 1 Workspaces > Management
  5. Click in the upper right corner of the target workspace.
    Figure 2 Workspace details page
  6. On the workspace details page, click Edit Tag.
    Figure 3 Edit Tag
  7. On the page for editing a tag, you can perform the following operations on the tag.
    Table 1 Managing tags
    Operation
    Add Tag
    1. On the tag management page, click Add Tag.
    2. Configure Tag key and Tag value.
      • A tag key can contain a maximum of 36 characters, including letters, digits, underscores (_), and hyphens (-).
      • A tag value can contain a maximum of 43 characters, including digits, letters, underscores (_), periods (.), and hyphens (-).
    3. Click OK.
    Delete Tag
    1. On the tag management page, locate the row containing the target tag and click Delete.
    1. Click OK.
