Upgrading the Service Edition
The upgrade method includes version upgrade and quota increase. Select a method as needed.
Scenario |
Description |
Upgrade the edition |
Increase the quota |
You can increase the quota for the edition you are using. For details, see Increasing the Quota. |
Upgrade the edition and increase the quota |
Upgrading from Standard to Professional: If you have purchased the standard edition, you can upgrade it to the professional edition and increase its quota at the same time. |
CAUTION:
Upgrading Basic to Standard or Professional
- Log in to the SecMaster console.
- Click
in the upper left corner of the management console and select a region or project. - In the navigation pane on the left, choose Purchased Resources. Locate the target region and click Upgrade.
- On the Buy SecMaster page, configure SecMaster parameters.
Table 2 Parameters for upgrading the basic edition Parameter
Current Configuration
The current configuration of the SecMaster edition in use. No manual configuration is required.
Upgrade Method
Version Upgrade is selected by default.
Optional Version
Select Standard or Professional.
Tag
TMS's predefined tag function is recommended for adding the same tag to different cloud resources. You can also create tags when purchasing SecMaster.
A tag consists of a tag key and a tag value.- A tag key can contain a maximum of 36 characters. It can only include digits, letters, underscores (_), and hyphens (-).
- A tag value can contain a maximum of 43 characters. It can only include digits, letters, underscores (_), periods (.), and hyphens (-).
A maximum of 10 tags can be added.
- Confirm the product details and click Next.
- After confirming that the order details are correct, read the SecMaster Disclaimer, select I have read and agree to the SecMaster Disclaimer, and click Pay Now.
- On the payment page, select a payment method and complete the payment.
- Click
in the upper left corner of the management console and select a region or project. - In the navigation pane on the left, choose Purchased Resources. On the page that is displayed, locate the region where you want to upgrade and click Upgrade.
Table 3 Parameters for upgrading the standard edition Parameter
The configuration of the current SecMaster edition.
Upgrade Method
Select Version Upgrade. You can also select Change Quota at the same time.
Optional Version
Select Professional to upgrade SecMaster to the professional edition.
Quota
The total quota must be greater than or equal to the total number of ECSs within your account. This value cannot be changed to a smaller one after your purchase is complete.
NOTE:- The maximum quota is 10,000.
- If some of your ECSs are not protected by SecMaster, threats to them cannot be detected in a timely manner, which may result in security risks, such as data leakage. To prevent this, increase the quota whenever your server quantity increases.
Tag
Effective Conditions
After completing your payment, you can see your SecMaster edition in the upper right corner of the management console.
Related Operations
- To change the asset quota, choose Purchased Resources, select the target region, and click Increase Quota. Then, increase the asset quota. For details, see Increasing the Quota.
- To enable the value-added package function, choose Purchased Resources and click Buy Value-add Pack in the upper right corner. For details, see Buying Value-Added Packages.
- If you plan to use SecMaster for a long time, yearly/monthly billing is recommended to save money. You can change the billing mode on the Purchased Resources page: Click Change Billing Mode on the right of the pay-per-use professional edition on this page and complete the change as required. For more details, see Changing the Billing Mode from Pay-per-Use to Yearly/Monthly.
- If your yearly/monthly edition is about to expire or has expired, you can choose Purchased Resources, select the target region, and click Renew to make a renewal. For details, see Renewing Your Subscriptions.
- If you no longer need the asset quota or value-added package, go to the Security Overview page, hover over the edition information in the upper right corner of the page, and click Unsubscribe or Cancel to unsubscribe from the service. For details, see Unsubscribing from SecMaster.
