Updated on 2026-10-10 GMT+08:00
Fixing Vulnerabilities
If HSS detects a vulnerability on a server, you need to handle the vulnerability in a timely manner based on its severity and your business conditions to prevent further vulnerability exploits.
If a vulnerability may harm your services, fix it as soon as possible.
  • You can fix Linux and Windows vulnerabilities on the console.
  • Automatic fixes are not supported for Web-CMS, application, and emergency vulnerabilities. You can manually fix them by referring to the suggestions provided on the vulnerability details page.
Notes and Constraints
  • CentOS 7, CentOS 8, Debian 9 and 10, Windows 2012 R2, and Ubuntu 14.04 and earlier have reached EOL and cannot be fixed because no official patches are available. You are advised to change to the OSs in active support.
  • Ubuntu 16.04 to Ubuntu 22.04 do not support free patch updates. You need to subscribe to Ubuntu Pro to install upgrade packages. If Ubuntu Pro is not configured, vulnerabilities will fail to be fixed.
  • Fixing kernel vulnerabilities may cause servers to be unavailable. Therefore, HSS does not automatically fix the server kernel vulnerabilities of CCE, MRS, or BMS. When batch fixing vulnerabilities, HSS filters out these types of vulnerabilities.
  • To handle vulnerabilities on a server, ensure the server is in the Running state, its agent status is Online, and its protection status is Protected.
  • Vulnerabilities manually imported cannot be fixed through the service.
Precautions
  • Vulnerability fixing operations cannot be rolled back. If a vulnerability fails to be fixed, services will probably be interrupted, and incompatibility issues will probably occur in middleware or upper layer applications. To prevent unexpected consequences, you are advised to use CBR to back up ECSs. For details, see Purchasing a Server Backup Vault. Then, use idle servers to simulate the production environment and test-fix the vulnerability. If the test-fix succeeds, fix the vulnerability on servers running in the production environment.
  • Servers need to access the Internet and use external image sources to fix vulnerabilities.
    • Linux OS: If your servers cannot access the Internet, or the external image sources cannot provide stable services, you can use the image source provided by Huawei Cloud to fix vulnerabilities. Before fixing vulnerabilities online, configure the Huawei Cloud image sources that match your server OSs. For details, see Image Source Management.
    • Windows OS: If your servers cannot access the Internet, ensure you have set up a patch server.
Fixing Vulnerabilities on the Console
Only Linux vulnerabilities and Windows vulnerabilities can be fixed using the repair function on the console.
  1. Log in to the SecMaster console.
  2. Click in the upper left corner of the management console and select a region or project.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Risk Prevention > Vulnerabilities.
    Figure 2 Accessing the Vulnerabilities page
  5. On the displayed page, click Linux Vulnerabilities or Windows Vulnerabilities.
  6. In the vulnerability list, click the name of the target vulnerability. The vulnerability details page is displayed.
  7. On the Vulnerability Details page, go to the Affected Resources area. In the resource list, locate the row that contains the target resource and click Repair in the Operation column.
    For details about how to handle a repair failure, see What Do I Do If Vulnerability Fix Failed?
  8. If a vulnerability is fixed, its status will change to Fixed. If it fails to be fixed, its status will change to Failed.
    Restart the system after you fixed a Linux kernel vulnerability, or the system will probably continue to warn you of this vulnerability.
Manually Fixing Software Vulnerabilities
One-click automatic fix of Web-CMS or application vulnerabilities is not supported. You can log in to the server to manually fix them by referring to the fix suggestions on the vulnerability details slide-out panel.
  • Vulnerability Fixing Commands
    On the basic information page of vulnerabilities, you can fix a detected vulnerability based on the provided suggestions. For details about the vulnerability fixing commands, see Table 1.
    • Restart the system after you fixed a Windows or Linux kernel vulnerability, or the system will probably continue to warn you of this vulnerability.
    • Fix the vulnerabilities in sequence based on the suggestions.
    • If multiple software packages on the same server have the same vulnerability, you only need to fix the vulnerability once.
    Table 1 Vulnerability fix commands
    OS
    Fix Command
    CentOS/Fedora /Euler/Red Hat/Oracle
    yum update Software name
    Debian/Ubuntu
    apt-get update && apt-get install Software name --only-upgrade
    Gentoo
    See the vulnerability fix suggestions for details.
  • Vulnerability Fixing Methods
    Vulnerability fixing may affect service stability. You are advised to use either of the following methods to avoid such impacts:
    • Method 1: Create a VM to fix the vulnerability.
      1. Create an image for the ECS whose vulnerability needs to be fixed. For details, see Creating a Full-ECS Image from an ECS.
      2. Use the image to create an ECS. For details, see Creating an ECS from an Image.
      3. Fix the vulnerability on the new ECS and verify the result.
      4. Switch services over to the new ECS and verify they are stably running.
      5. Release the original ECS. If a fault occurs after the service switchover and cannot be rectified, you can switch services back to the original ECS.
    • Method 2: Fix the vulnerability on the current server.
      1. Create a backup for the ECS to be fixed. For details, see Creating a CSBS Backup.
      2. Fix vulnerabilities on the current server.
      3. If services become unavailable after the vulnerability is fixed and cannot be recovered in a timely manner, use the backup to restore the server. For details, see Using Backups to Restore Servers.
    • Use method 1 if you are fixing a vulnerability for the first time and cannot estimate the impact on services. You are advised use pay-per-use billing for newly created ECSs. After the service switchover, you can change the billing mode to yearly/monthly. In this way, you can release the ECSs at any time to save costs if the vulnerability fails to be fixed.
    • Use method 2 if you have fixed the vulnerability on similar servers before.
Verifying the Vulnerability Fix
After a vulnerability is fixed, you are advised to verify it immediately.
Table 2 Verifying vulnerability fixes
Method
Operation
Manual verification
  • Click Verify on the vulnerability details page.
  • Run the following command to check the software upgrade result and ensure that the software has been upgraded to the latest version:
    • CentOS, Fedora, EulerOS, Red Hat, and Oracle: rpm -qa | grep Software name
    • Debian and Ubuntu: dpkg -l | grep Software name
    • Gentoo: emerge --search Software name
  • Perform a manual scan on the HSS console to check the vulnerability fixing result.
Automatic verification
HSS performs a full scan every early morning. If you do not perform a manual verification, you can view the system check result on the next day after you fix the vulnerability.
Related Operations
If you evaluate that some vulnerabilities do not affect your services and do not want to view the vulnerabilities in the vulnerability list, you can whitelist the vulnerabilities. After they are whitelisted, the vulnerabilities will be ignored in the vulnerability list and no alarms will be reported. The vulnerabilities will not be scanned and the vulnerability information will not be displayed when the next vulnerability scan task is executed. For details, see Handling Vulnerabilities.
