Managing Connections
This section describes how to perform the following operations: Viewing Connections and Deleting a Data Connection.
Viewing Connections
- Log in to the SecMaster console.
- Click
in the upper left corner of the management console and select a region or project.
- Click
in the upper left corner of the page and choose Security & Compliance > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
.Figure 2 Accessing the connection management page
- On the Connections tab, view connection details.
Table 1 Connection parameters Parameter
Connection Name
Connection name
Connection Type
Connection type
Connection Info
Information about the connection
Channel
Number of channels that are used by the connection
Description of the connection
Operation
Operations such as editing or deleting connections
- Click
- Click
Figure 3 Workspace management page
.Figure 4 Accessing the connection management page
- On the Connections page, locate the row that contains the target connection and click Delete in the Operation column.
