Help Center/ SecMaster/ User Guide/ Threats/ Alerts/ Adding and Editing an Alert
Updated on 2026-10-10 GMT+08:00
This section describes how to add or edit an alert.
  • Adding an Alert: SecMaster can manage cloud and off-cloud assets. For details about asset management, see Overview. Alerts for cloud assets can be automatically synchronized to SecMaster. For details, see Enabling Log Access. Alerts for off-cloud assets need to be connected to SecMaster manually. For details, see Adding an Alert or Importing Alerts.
  • Editing an Alert: If the alert status or basic information changes, you can edit alert parameters.
Notes and Constraints
  • A maximum of 100 alert records can be added each day. If an alert fails to be added or imported due to incorrect field settings, it is still counted towards your quota. New and imported alerts share the daily quota of new alerts.
Adding an Alert
  1. Log in to the SecMaster console.
  2. Click in the upper left corner of the management console and select a region or project.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Threats > Alerts.
    Figure 2 Alerts
  5. On the Alerts page, click Add. On the Add page displayed on the right, set parameters as described in the following table.
    Table 1 Alert parameters
    Basic Information
    Alert Name
    User-defined alert name. The value must contain:
    • Only uppercase letters, lowercase letters, digits, and the special characters: -_ ()
    • A maximum of 2,550 characters
    Alert Type
    Alert type
    Alert Severity
    Alert severity. The options are Informational, Low, Medium, High, and Critical. For details about alert severity levels, see Alert Severity Levels.
    Status
    Select an alert status. You can track the handling progress of an alert through its status. The options are Open, Blocked, and Closed.
    • Open: For alerts that have not been handled and still require further attention, set their status to Open.
    • Blocked: For alerts that cannot be handled temporarily but still need to be addressed later, set their status to Blocked.
    • Closed: For alerts that have been handled and require no further action, set their status to Closed.
    (Optional) Owner
    Select the primary owner to track or handle the alert.
    Data Source Product Name
    Data source name
    Data Source Type
    Type of the data source. The options are Cloud Service, Third-party, and Private.
    • Cloud Service: Aggregates alerts from cloud service logs that have been connected to SecMaster. For details, see Cloud Service Log Access Supported by SecMaster.
    • Third-party: Aggregates alerts reported by third-party products.
    • Private: Aggregates alerts reported by your private products.
    Timeline
    First Occurrence Time
    Time when an alert is generated for the first time.
    (Optional) Last Occurrence Time
    Last time when an alert was generated
    (Optional) Planned Closure Time
    Time when the alert plan is disabled.
    Other
    (Optional) Verification Status
    Select the alert verification status to indicate whether the alert is a real one and whether it has a negative impact. The options are as follows: Unknown, Positive, and False positive.
    • Unknown: It is unclear whether the alert is associated with an attack.
    • Positive: It has been confirmed that the alert was triggered by a successful attack.
    • False positive: It has been confirmed that the alert was triggered by a failed attack.
    • Suspicious: The alert is triggered by a suspicious attack, such as an attack attempt.
    • Allow: The alert is triggered by an HSS alarm with no real attack behavior.
    • Non-attack information: The alert is triggered by non-attack threats, such as system vulnerability alarms, risky accounts, and weak passwords.
    (Optional) stage
    Alert phase.
    • Preparation: Prepare resources to process alerts.
    • Detection and analysis: Detect and analyze the cause of an alert.
    • Containment, extradition, and recovery: Handle an alert.
    • Post Incident Activity: Complete follow-up activities.
    (Optional) Debugging data
    Whether to enable simulated debugging.
    (Optional) Labels
    Alert labels.
    Alert description. The rules are as follows:
    • Only uppercase letters, lowercase letters, digits, and the following special characters are allowed: -_ ()
    • A maximum of 10,240 characters are allowed.
  6. Click OK. You can check details about the alert you add. Path: In the navigation pane on the left, choose Threats > Alerts.
Editing an Alert
    Figure 3 Workspace management page
    Figure 4 Alerts
  5. In the alert list, locate the row that contains the target alert, and click Edit in the Operation column.
  6. On the Edit slide-out that is displayed, modify alert parameters. For details about the parameters, see the following table.
    Table 2 Alert parameters
    Basic Information
    Alert Name
    Alert Type
    Alert type
    Alert Severity
    Status
    (Optional) Owner
    Name of the data source, which cannot be changed
    Data Source Type
    Type of the data source, which cannot be changed
    Timeline
    Suggestions
    Recommended Solution
    Description of the recommended alert handling method.
    Other
    Labels
    Alert labels.
    Debugging data
    Whether to enable simulated debugging. This parameter cannot be modified once configured.
    stage
    Alert stage.
  7. Click OK. You can check details about the alert. Path: In the navigation pane on the left, choose Threats > Alerts.
