Managing Data Delivery
This section describes how to manage delivery tasks.
A data delivery task has been added.
Viewing a Data Delivery Task
- Log in to the SecMaster console.
- Click
in the upper left corner of the management console and select a region or project.
- Click
in the upper left corner of the page and choose Security & Compliance > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
- In the navigation pane on the left, choose Data Delivery tab.
. On the security analysis page displayed, select the Figure 2 Data delivery task list
- On the delivery task list page, view existing delivery tasks.
Table 1 Delivery task parameters Operation
Name/ID
Delivery task name and ID.
Data Source
Pipeline where the data source is located.
Consumption Policy
Consumption policy of a delivery task.
Destination Type
Type of the data delivery destination, such as OBS and LTS.
Destination
Data delivery destination.
Monitoring
Data delivery monitoring status. You can click the monitoring icon to view the data consumption information.
Status
The status of the delivery task.
- Delivering: The data delivery task has been created and data delivery authorization has been completed. Data is being delivered.
- Suspended
- Pending authorization: The data delivery task has been created, but data delivery authorization is not completed.
- Authorization failed: The data delivery task has been created, but data delivery authorization is rejected.
- Delivery canceled: The data delivery task is canceled.
Created
Time when a delivery task is created
Operation
You can delete or suspend a data delivery task.
Suspending a Delivery Task
After a data delivery task is added and authorized, the delivery task status changes to Delivering. To stop the delivery, you can suspend the target delivery task.
- Click
- Click
Figure 3 Workspace management page
. On the security analysis page displayed, select the Figure 4 Data delivery task list
- On the Data Delivery tab page, locate the row of the target delivery task and click Suspend in the Operation column.
After a delivery task is suspended, the delivery task status changes to Suspended, indicating that the delivery task is suspended successfully.
Starting a Delivery Task
You can restart a suspended delivery task.
- Click
- Click
Figure 5 Workspace management page
. On the security analysis page displayed, select the Figure 6 Data delivery task list
- On the Data Delivery tab page, locate the row of the target delivery task and click Start in the Operation column.
After a delivery task is restarted, the delivery task status changes to Delivering, indicating that the delivery task is successfully started.
Deleting a Delivery Task
If a data delivery task is no longer needed, you can delete it.
- Click
- Click
Figure 7 Workspace management page
. On the security analysis page displayed, select the Figure 8 Data delivery task list
- On the Data Delivery tab page, locate the row of the target delivery task and click Delete in the Operation column and click OK in the displayed dialog box.
