Submitting a Playbook Version
This section describes how to submit a playbook version for review.
The workflow bound to the playbook has been enabled by referring to Enabling a Workflow.
- Click in the upper left corner of the management console and select a region or project.
- Click in the upper left corner of the page and choose Security & Compliance > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
- In the navigation pane on the left, choose Security Orchestration > Playbooks.
Figure 2 Accessing the Playbooks tab
- In the Operation column of the target playbook, click Versions.
Figure 3 Version Management slide-out panel
- On the Version Management slide-out panel, in the version information area, locate the row containing the desired playbook version, and click Submit in the Operation column.
- In the confirmation dialog box, click OK to submit the playbook version.
- After the playbook version is submitted, Version Status changes to Pending review.
- After a playbook version is submitted, it cannot be edited. If you need to edit it, you can create a version or reject it during review.
Follow-up Operations
A submitted playbook version needs to be reviewed. For details, see Reviewing a Playbook Version.
