Managing Pipelines
A data transfer message topic and a storage index form a pipeline. This topic describes how to manage data pipelines. You can:
- Creating a Pipeline: If you need to use security analysis, data analysis, and intelligent modeling features in SecMaster, you need to create pipelines.
- Viewing Pipeline Details: You can view the pipeline details, including the pipeline name, data space, and creation time.
- Editing a Pipeline: You can modify the pipeline information, such as the number of shards, description, and lifecycle.
- Deleting a Pipeline: You can delete a pipeline. Data in the pipeline will also be deleted and cannot be restored. Exercise caution when performing this operation.
Limitations and Constraints
- A maximum of 20 pipelines can be created in a workspace in a region for an account.
- Pipelines created by the system cannot be edited.
- Pipelines created by the system cannot be deleted.
- The throughput of a pipeline cannot exceed 4 MB/s.
Creating a Pipeline
- Log in to the SecMaster console.
- Click
in the upper left corner of the management console and select a region or project. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
- In the navigation pane on the left, choose .
Figure 2 Accessing the Security Analysis tab
- (Optional) Add a data space. For details, see Adding a Data Space.
- In the data space navigation tree on the left, click
on the right of the data space name and select Create Pipeline.
Figure 3 Create Pipeline
- On the Create Pipeline page, configure pipeline parameters. For details about the parameters, see Table 1.
Table 1 Parameters for creating a pipeline Parameter
Data Space
Data space the pipeline belongs to. This parameter is generated by the system by default.
Pipeline Name
Name of the pipeline.
It must meet the following requirements:
- The name can contain 5 to 64 characters.
- The name must be unique in the workspace and cannot be the same as the name of any other pipeline in the workspace.
- The name must start with a lowercase letter and can contain only lowercase letters, digits, and underscores (_). The name cannot end with an underscore (_) or contain consecutive underscores (_).
- The name cannot start with the reserved prefix isap_, csb_, secmaster_, sec_, s_sec_, i_sec_, l_sec_, or security_.
Shards
The number of shards of the pipeline. The value ranges from 1 to 64.
An index can store a large amount of data that exceeds the hardware limits of a node. To solve this problem, Elasticsearch subdivides your index into multiple pieces called shards. When creating an index, you can specify the number of shards as required. Each shard is in itself a fully-functional and independent "index" that can be hosted on any node in the cluster.
Lifecycle
Data retention period in the pipeline, in days. Value range: 7 to 180
Remarks on the pipeline. This parameter is optional.
- Click OK.
You can click the data space name or
next to the data space to view the created pipeline.
- Click
Figure 4 Workspace management page
Figure 5 Accessing the Security Analysis tab
- In the data space navigation tree on the left, click a data space name to show the pipeline list.
Figure 6 Viewing pipeline details
- Click
next to a pipeline name you want to view. The Pipeline Details pane is displayed on the right of the page.
Table 2 Pipeline parameters Parameter
Workspace Name
Name of the workspace to which the pipeline belongs.
Workspace ID
ID of the workspace to which the pipeline belongs.
Data Space Name
Name of the data space to which the pipeline belongs.
Data Space ID
ID of the data space to which the pipeline belongs.
Pipeline Name
Pipeline ID
ID of the pipeline.
Shards
Number of shards of the pipeline.
Lifecycle
Retention period of the data in the pipeline.
Created
Time when the pipeline was created.
Description of the pipeline.
Editing a Pipeline
- Click
Figure 7 Workspace management page
Figure 8 Accessing the Security Analysis tab
Figure 9 Viewing pipeline details
- Click More > Edit next to the pipeline name.
Figure 10 Entry for editing a pipeline
- On the Edit Pipeline page, configure pipeline parameters. For details about the parameters, see Table 3.
Table 3 Parameters for editing a pipeline Parameter
Data Space
Data space to which the pipeline belongs. This parameter cannot be modified.
Pipeline Name
Name you specified for the pipeline. The name cannot be changed after the pipeline is created.
Shards
Lifecycle
Lifecycle of data in the pipeline. Value range: 7 to 180
- Click OK.
- Click the data space name or
next to the data space to view the pipeline. Click
Deleting a Pipeline
- Click
Figure 11 Workspace management page
Figure 12 Accessing the Security Analysis tab
Figure 13 Viewing pipeline details
- Click More > Delete next to the pipeline name.
Figure 14 Deleting a pipeline
- In the dialog box displayed, click OK.
