Enabling Data Consumption
Data consumption refers to the process during which third-party software or cloud products consume the log data in real time through a client. It is a sequential read/write from/into full data.
SecMaster provides the data consumption function and supports real-time data consumption through the client.
- Log in to the SecMaster console.
- Click
in the upper left corner of the management console and select a region or project.
- Click
in the upper left corner of the page and choose Security & Compliance > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
.Figure 2 Accessing the Security Analysis tab
- In the data space navigation tree on the left, click the data space name to expand all pipelines. Next to the name of the target pipeline, click More > Consume.
Figure 3 Accessing the data consumption page
- On the Data Consumption page, click
next to Current Status to enable data consumption.
After the function is enabled, the consumption configuration information is displayed, as shown in Table 1.
Figure 4 Enabling Data ConsumptionTable 1 Data consumption parameters Parameter
Status
Status of the data consumption function in the current pipeline
Pipeline Name
Name of the current pipeline
Subscriber
The preset subscription mode in the system. This parameter determines how data is transmitted to data consumers.
Access Node
Access node of the current data.
Related Operations
After data consumption is enabled, you can click next to Status on the Data Consumption page to disable data consumption.
