Help Center/ SecMaster/ User Guide/ Resource Manager/ Viewing Asset Information
Updated on 2026-02-06 GMT+08:00
On the Resource Manager page, you can view the asset name, type, and protection status. You can view assets on and off this cloud.
Viewing Resource Information
  1. Log in to the SecMaster console.
  2. Click in the upper left corner of the management console and select a region or project.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Resource Manager > Resource Manager.
    Figure 2 Resource Manager
  5. (Optional) Complete the asset subscription first. If you have done this once, skip this step.
    SecMaster can synchronize only asset information in the workspace where asset subscription is enabled. After the subscription, the resource information will be displayed in SecMaster within one minute.
    Only cloud resources can be subscribed to and synchronized to SecMaster. Subscribing to resources in a region to multiple workspaces is not recommended.
    1. On the Resource Manager page, click Asset Subscription in the upper right corner.
    2. On the Asset Subscription page sliding from the right, locate the row that contains the region where the target resource is located, and enable subscription.
    3. Click OK.
      After asset subscription, you can click System Synchronize Assets on the Resource Manager page to synchronize asset information again. The basic edition allows you to synchronize assets one time per day, and the standard or professional edition allows you to synchronize assets 20 times per day. If you exceed this threshold, the system displays error message "Insufficient resource synchronization quota." In this case, synchronize assets again the next day.
  6. On the displayed page, view the resource details.
    • You can view resource information by resource type. For example, you can select the Servers tab to view details about servers you have. You can view resources on the following tabs: Servers, Websites, Databases, VPCs, EIPs, and Devices. On the All Resources tab, you can view all resources.
    • Departments and Service Systems: This tab displays the Department and Service System information of the assets.
    • You can view the total number of assets below the asset list. You can view a maximum of 10,000 asset records page by page. To view more than 10,000 asset records, optimize the filter criteria.
    • To view more details about an asset, check its asset type. Then, go to the corresponding resource tab and click the resource name of the asset to go to its details page.
      For example, to view details about a server, select the Servers tab. On the displayed tab, click the resource name of the target server to go to its details page.
      • On the asset details page, you can view the environment, asset, and network details related to the asset.
      • Edit the owner, service system, and department of the resource. You can also bind the resources to or unbind the resources from an owner, service system, or department.
    • You can click in the upper right corner of the asset list and select the fields you want to display in the asset list.
    Table 1 Asset sources and corresponding security products
    Asset Type
    Asset Name
    Source
    Security Product
    Cloud asset
    Servers
    Elastic Cloud Server (ECS)
    Host Security Service (HSS)
    Cloud asset
    Website
    Web Application Firewall (WAF)
    Cloud asset
    Database
    Relational Database Service (RDS)
    Database Security Service (DBSS)
    Cloud asset
    VPC
    Virtual Private Cloud (VPC)
    Cloud Firewall (CFW)
    Cloud asset
    EIP
    Elastic IP (EIP)
    CNAD Basic (Anti-DDoS)
    Off-cloud asset
    Device
    Off-cloud assets include on-premises servers, IDC servers, servers on third-party cloud platforms. In a word, off-cloud assets include assets that are not on Huawei Cloud.
    After the asset information is synchronized to SecMaster, the protection status of assets will be displayed on the SecMaster console. The protection status is as follows:
    • If Protection Status for an asset is Protected, the corresponding security product has been enabled for the asset.
    • If Protection Status for an asset is Unprotected, the corresponding security product has not been purchased or enabled for the asset. If you want to protect target assets, purchase corresponding security products and enable protection. For example, if you want to protect ECSs using HSS, purchase HSS and enable HSS for each ECS.
      For details about security products, see HSS Operation Guide, WAF Operation Guide, DBSS Operation Guide, CFW Operation Guide, and Anti-DDoS Operation Guide.
    • If protection status for an asset is --, the corresponding security product is not supported in the current region.
