- What's New
- Product Bulletin
- Getting Started
User Guide
- Permissions Management
Asynchronous Replication
- Managing a Replica Pair
- Managing a Protection Group
- Managing Protected Instances
- Managing DR Drills
- Managing Clients
- Synchronous Replication Management (for Installed Base Operations)
- Appendixes
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
SDRS APIs
- Job
- API Version
- Active-Active Domain
Protection Group
- Creating a Protection Group
- Querying Protection Groups
- Querying the Details of a Protection Group
- Deleting a Protection Group
- Changing the Name of a Protection Group
- Enabling Protection or Enabling Protection Again for a Protection Group
- Disabling Protection for a Protection Group
- Performing a Failover for a Protection Group
- Performing a Planned Failover for a Protection Group
Protected Instance
- Creating a Protected Instance
- Deleting a Protected Instance
- Querying Protected Instances
- Querying Details About a Protected Instance
- Changing the Name of a Protected Instance
- Attaching a Replication Pair to a Protected Instance
- Detaching a Replication Pair from a Protected Instance
- Adding an NIC to a Protected Instance
- Deleting an NIC from a Protected Instance
- Modifying the Specifications of a Protected Instance
- Batch Creating Protected Instances
- Batch Deleting Protected Instances
- Replication Pair
- DR Drill
- Tag Management
- Task Center
- Tenant Quota Management
- Appendixes
- Change History
- SDK Reference
- Common Problems
Synchronous Replication (for Installed Base Operations)
- Do I Need to Manually Create DR Resources?
- What Can I Do When the EIP Cannot Be Pinged After I Perform a Switchover for a Protection Group Containing a SUSE Server?
- What Can I Do If the NIC Names of the DR Drill Server and Production Site Server Are Different?
- What Can I Do If hostname of the Production Site Server and DR Site Server Are Different After a Switchover or Failover?
- Why NICs of DR Site Servers Are Not Displayed After I Perform a Failover?
- What Are the Precautions If the Production Site Server Uses the Key Login Mode?
- What Should I Pay Attention to When Logging In to the Server After the First Time Ever I Executed a Switchover, Failover, or DR Drill?
- How Do I Use a Resource Package?
- How Do I Handle the drm Process Start Failure?
- Failed to Install and Configure Disaster Recovery Gateway When Process drm Exists But Port 7443 Is Not Listened
- What Can I Do If the Name of a Production Site Server or the Host Name Reported by the Gateway Is Incorrect and Always Displayed as "localhost"?
- What Can I Do If the Disaster Recovery Site VM Is Not Started After a Switchover?
- How Do I Obtain the Installation Package on a Production Site Server from the Gateway?
- How Do I Enable or Disable an ECS Firewall and Add a Port Exception to the Firewall?
- Why Can't I Find the Disaster Recovery Gateway When Associating a Replica Pair with It?
- Why Is No Production Site Server Displayed When I Create Protected Instances?
- Videos
- Glossary
- Best Practices
Show all
Creating a Replication Pair
Create replication pairs for desired disks of a specified protection group. When you create a replication pair:
- If the protection group status is Available, protection is disabled. Creating the replication pair only establishes the replication relationship between the production site disk and DR site disk, but data between the disks is not synchronized. To synchronize data, enable protection.
- If the protection group status is Protecting, protection is enabled. After a replication pair has been created, data synchronization automatically starts.
In a replication pair, the name of the DR site disk is the same as that of the production site disk, but their IDs are different.
To change disk name, click the disk name on the replication pair details page to go to the disk details page and change it.
- The protection group is in the Available or Protecting state.
- If the servers in the protection group are ECSs, ensure that the disks used to create replication pairs are in the Available state.
- Click Service List and choose Storage > Storage Disaster Recovery Service.
The Storage Disaster Recovery Service page is displayed.
- Locate the protection group where you want to add replication pairs and click Replication Pairs.
The protection group details page is displayed.
- On the Replication Pairs tab, click Create Replication Pair.
The Create Replication Pair page is displayed.
- Set the parameters by referring to Table 1.
Table 1 Parameter description Parameter
Example Value
Protection Group Name
Name of the protection group where you want to create replication pairs. You do not need to configure it.
Protection-Group-test
Protection Group ID
ID of the protection group
619c57e9-3927-48f8-ad14-3e293260b8a0
DR Direction
Replication direction of the protection group. You do not need to configure it.
Production Site
AZ where the production site resides
Production Site Disk
This parameter is mandatory.
The following two options are available:- EVS
- DSS
EVS
DR Site Disk
- DSS
Disks are classified as EVS and DSS disks based on whether the storage resources used by the disks are exclusive. DSS disks are provided for users exclusively.
Determine whether to use DSS disks for the DR site. The disks at the production and DR site do not need to be of the same type.
EVS
Storage Pool
- If you select EVS for DR Site Disk, Storage Pool is not required.
- If you select DSS for DR Site Disk, Storage Pool is mandatory.
dss-01
Replication Pair
Replication pair name. This parameter is mandatory.
A replication pair name is defined for classification and future search.
replication_001
DR Site Disk and Storage Pool are available only when DSS is selected.
- Click Create Now.
- On the Confirm page, confirm the replication pair information.
- If you do not need to modify the information, click Submit.
- If you need to modify the information, click Previous.
- Click Back to Protection Group Details Page and view the replication pair list.
If the replication pair status changes to Available or Protecting, it has been created successfully.
