Attaching a Replication Pair
You can attach a replication pair to a protected instance. Then, the production site disk is attached to the production site server, and the DR site disk is attached to the DR site server.
After protection is enabled for a protection group, when data is written into the production site disk, the same data is written into the DR site disk synchronously.
Notes and Constraints
- If there are five replication pairs that are not attached to any protected instance, you cannot create any new replication pair.
- The protection group is in the Available or Protecting state.
- The protected instance is in the Available or Protecting state.
- The replication pair is in the Available or Protecting state.
- The non-shared replication pair has not been attached to any protected instance.
- Click Service List and choose Storage > Business Recovery Service.
The Business Recovery Service page is displayed.
- Locate the protection group where you want to attach replication pairs and click Protected Instances.
The protection group details page is displayed.
- On the Protected Instances tab, locate the row containing the desired protected instance and click Attach in the Operation column.
The Attach Replication Pair page is displayed.
- Select the replication pair, select a desired device name, and click OK.
The replication pair is attached to the specified protected instance.
