Configuring a Disaster Recovery Gateway
Before using a gateway and disaster recovery site servers for the first time, you need to configure the gateway.
- The recommended ECS specifications to deploy the gateway are 8 vCPUs and 16 GB memory. Only Linux is supported. Huawei Cloud EulerOS 2.0 and EulerOS 2.9\2.10 are recommended, or see Supported OSs.
- The region, AZ, and VPC of the gateway ECS must be the same as those of the production site servers.
- It is recommended that you deploy the disaster recovery gateway and proxy client in the same security group and only allow ECSs within the security group to communication with each other. For details, see Security Group Configuration Examples.
- For security purposes, ensure that the AK/SK pair used for configuring the gateway belongs to the account that is using SDRS. Or, protected instances cannot be created.
- In 24.6.0 or an earlier version, ensure that you have upgraded the SDRS software on the gateway and production site servers to 24.9.0 or later and reconfigured the gateway according to the "Procedure for 24.9.0 or Later" part in this section.
In the following example, sdrs_linux_amd64_24.6.0.20240627203949.tar.gz is the package (24.6.0) used to configure the gateway.
- Run the following command in the /opt/cloud/sdrs directory to configure the gateway:
sh register_gateway.sh
Figure 1 Executing the script- In cross-AZ scenarios, configure the following parameters:
Figure 2 Script execution example in the cross-AZ scenario
Table 1 Parameters for configuring cross-AZ disaster recovery Parameter
How to Obtain
Example Value
DR Scene
Replication
- 0: IDC-to-cloud
- 1: Cross-AZ
- 2: Cross-region
- 3: IDC VMware-to-cloud
source platform type
Type of the production site
- 0: Huawei public cloud
- 1: Huawei private cloud
- 2: VMware platform
0
source project id
Project ID of the production region
Log in to the console, select the production region, and choose My Credentials > API Credentials to view the project ID.
51af777371904892a49a0c3e3e53de44
source region code
Production region ID
Obtain the SDRS endpoint by referring to SDRS Endpoints.
cn-east-2
source ecs endpoint
ECS endpoint in the production region
Obtain the ECS endpoint by referring to ECS Endpoints.
source evs endpoint
EVS endpoint in the production region
Obtain the EVS endpoint by referring to EVS Endpoints.
source iam ak
Access key ID in the production region
Obtain AK/SK by referring to How Do I Obtain an Access Key (AK/SK)?
RZSAMHULWKKE71N0XHUT
source iam sk
Secret access key in the production region
K7bXplAT0pEpy4SAiN2fHUwEtxvgmK3IqyhqnMTA
target sdrs endpoint
SDRS endpoint in the disaster recovery region
sdrs.cn-east-2.myhuaweicloud.com
- In cross-region scenarios, configure the following parameters:
Figure 3 Script execution example in the cross-region scenario
Table 2 Parameters for configuring cross-region disaster recovery Parameter
How to Obtain
Example Value
DR Scene
Replication
- 0: IDC-to-cloud
- 1: Cross-AZ
- 2: Cross-region
2
0
source project id
Log in to the console and choose My Credentials > API Credentials to view the project ID.
source region code
ID of the current region
cn-east-2
source ecs endpoint
source evs endpoint
source iam ak
source iam sk
target platform type
Type of the disaster recovery site
0
target project id
Project ID of the disaster recovery region
target iam ak
Access key ID in the disaster recovery region
target iam sk
Secret access key in the disaster recovery region
- In IDC-to-cloud scenarios, configure the following parameters:
Figure 4 Script execution example in the IDC-to-cloud scenario
Table 3 Parameters for configuring IDC-to-cloud disaster recovery Parameter
How to Obtain
Example Value
DR Scene
Type
- 0: IDC-to-cloud
- 1: Cross-AZ
- 2: Cross-region
3
2
source project id
source region code
cn-east-2
source ecs endpoint
source evs endpoint
source iam ak
source iam sk
In the following example, sdrs_xxxx_24.9.0.xxxx.tar.gz is the package (24.9.0) used to configure the gateway.
Figure 5 Executing the script- In cross-AZ scenarios, configure the following parameters:
Figure 6 Script execution example in the cross-AZ scenario
Table 4 Parameters for configuring cross-AZ disaster recovery Parameter
How to Obtain
Example Value
DR Scene
Replication
- 0: IDC-to-cloud
- 1: Cross-AZ
- 2: Cross-region
0
source project id
source ecs endpoint
source evs endpoint
source iam ak
source iam sk
Figure 7 Script execution example in the cross-region scenario
Table 5 Parameters for configuring cross-region disaster recovery Parameter
How to Obtain
Example Value
DR Scene
Replication
- 0: IDC-to-cloud
- 1: Cross-AZ
- 2: Cross-region
2
0
source project id
source ecs endpoint
source evs endpoint
source iam ak
source iam sk
0
target project id
Log in to the console, select the disaster recovery region, and choose My Credentials > API Credentials to view the project ID.
target ecs endpoint
ECS endpoint in the disaster recovery region
target evs endpoint
EVS endpoint in the disaster recovery region
target iam ak
target iam sk
- V2C scenario
Figure 8 Script execution example in the IDC-to-cloud scenario (V2C)
Table 6 Parameters for configuring IDC-to-cloud disaster recovery Parameter
How to Obtain
Example Value
DR Scene
Type
- 0: IDC-to-cloud
- 1: Cross-AZ
- 2: Cross-region
3
- 0: VMware platform
0
0
target project id
target ecs endpoint
target evs endpoint
target iam ak
target iam sk
- H2C scenario
Figure 9 Script execution example in the IDC-to-cloud scenario (H2C)
Table 7 Parameters for configuring IDC-to-cloud disaster recovery (H2C) Parameter
How to Obtain
Example Value
DR Scene
Replication
- 0: IDC-to-cloud
- 1: Cross-AZ
- 2: Cross-region
0
0
source project id
source ecs endpoint
source evs endpoint
source iam ak
source iam sk
0
target project id
target ecs endpoint
target evs endpoint
target iam ak
target iam sk
- V2C scenario
How to Obtain
Example Value
DR Scene
Replication
- 0: IDC-to-cloud
- 1: Cross-AZ
- 2: Cross-region
0
source project id
source region code
cn-east-2
source ecs endpoint
source evs endpoint
source iam ak
source iam sk
How to Obtain
Example Value
DR Scene
Replication
- 0: IDC-to-cloud
- 1: Cross-AZ
- 2: Cross-region
2
0
source project id
source region code
cn-east-2
source ecs endpoint
source evs endpoint
source iam ak
source iam sk
0
target project id
target iam ak
target iam sk
How to Obtain
Example Value
DR Scene
Type
- 0: IDC-to-cloud
- 1: Cross-AZ
- 2: Cross-region
3
2
source project id
source region code
cn-east-2
source ecs endpoint
source evs endpoint
source iam ak
source iam sk
How to Obtain
Example Value
DR Scene
Replication
- 0: IDC-to-cloud
- 1: Cross-AZ
- 2: Cross-region
0
source project id
source ecs endpoint
source evs endpoint
source iam ak
source iam sk
How to Obtain
Example Value
DR Scene
Replication
- 0: IDC-to-cloud
- 1: Cross-AZ
- 2: Cross-region
2
0
source project id
source ecs endpoint
source evs endpoint
source iam ak
source iam sk
0
target project id
target ecs endpoint
target evs endpoint
target iam ak
target iam sk
- V2C scenario
How to Obtain
Example Value
DR Scene
Type
- 0: IDC-to-cloud
- 1: Cross-AZ
- 2: Cross-region
3
0
0
target project id
target ecs endpoint
target evs endpoint
target iam ak
target iam sk
- H2C scenario
How to Obtain
Example Value
DR Scene
Replication
- 0: IDC-to-cloud
- 1: Cross-AZ
- 2: Cross-region
0
0
source project id
source ecs endpoint
source evs endpoint
source iam ak
source iam sk
0
target project id
target ecs endpoint
target evs endpoint
target iam ak
target iam sk
- V2C scenario
