- What's New
- Product Bulletin
- Getting Started
User Guide
- Permissions Management
Asynchronous Replication
- Managing a Replica Pair
- Managing a Protection Group
- Managing Protected Instances
- Managing DR Drills
- Managing Clients
- Synchronous Replication Management (for Installed Base Operations)
- Appendixes
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
SDRS APIs
- Job
- API Version
- Active-Active Domain
Protection Group
- Creating a Protection Group
- Querying Protection Groups
- Querying the Details of a Protection Group
- Deleting a Protection Group
- Changing the Name of a Protection Group
- Enabling Protection or Enabling Protection Again for a Protection Group
- Disabling Protection for a Protection Group
- Performing a Failover for a Protection Group
- Performing a Planned Failover for a Protection Group
Protected Instance
- Creating a Protected Instance
- Deleting a Protected Instance
- Querying Protected Instances
- Querying Details About a Protected Instance
- Changing the Name of a Protected Instance
- Attaching a Replication Pair to a Protected Instance
- Detaching a Replication Pair from a Protected Instance
- Adding an NIC to a Protected Instance
- Deleting an NIC from a Protected Instance
- Modifying the Specifications of a Protected Instance
- Batch Creating Protected Instances
- Batch Deleting Protected Instances
- Replication Pair
- DR Drill
- Tag Management
- Task Center
- Tenant Quota Management
- Appendixes
- Change History
- SDK Reference
- Common Problems
Synchronous Replication (for Installed Base Operations)
- Do I Need to Manually Create DR Resources?
- What Can I Do When the EIP Cannot Be Pinged After I Perform a Switchover for a Protection Group Containing a SUSE Server?
- What Can I Do If the NIC Names of the DR Drill Server and Production Site Server Are Different?
- What Can I Do If hostname of the Production Site Server and DR Site Server Are Different After a Switchover or Failover?
- Why NICs of DR Site Servers Are Not Displayed After I Perform a Failover?
- What Are the Precautions If the Production Site Server Uses the Key Login Mode?
- What Should I Pay Attention to When Logging In to the Server After the First Time Ever I Executed a Switchover, Failover, or DR Drill?
- How Do I Use a Resource Package?
- How Do I Handle the drm Process Start Failure?
- Failed to Install and Configure Disaster Recovery Gateway When Process drm Exists But Port 7443 Is Not Listened
- What Can I Do If the Name of a Production Site Server or the Host Name Reported by the Gateway Is Incorrect and Always Displayed as "localhost"?
- What Can I Do If the Disaster Recovery Site VM Is Not Started After a Switchover?
- How Do I Obtain the Installation Package on a Production Site Server from the Gateway?
- How Do I Enable or Disable an ECS Firewall and Add a Port Exception to the Firewall?
- Why Can't I Find the Disaster Recovery Gateway When Associating a Replica Pair with It?
- Why Is No Production Site Server Displayed When I Create Protected Instances?
- Videos
- Glossary
- Best Practices
Show all
Enabling Protection
You can enable protection for a protected instance in a protection group.
After protection is enabled, data synchronization starts for the protected instance.
The status of the protected instance is Pending protection or Enabling protection failed.
- Click Service List and choose Storage > Storage Disaster Recovery Service.
The Storage Disaster Recovery Service page is displayed.
- Choose Asynchronous Replication. In the right pane, locate the replica pair housing the protected instance you want to enable protection and click the number in the Protected Instances column.
The Protection Groups tab page is displayed.
- In the navigation tree, choose the target protection group.
The protection group details page is displayed.
- In the Protected Instances area, locate the target protected instance, choose More > Enable Protection in the Operation column.
If you want to enable protection for multiple protected instances, select the desired instances and click Enable Protection above the instance list.
- In the displayed dialog box, confirm the protected instance information and click Yes to enable protection. The protected instance status changes to Enabling protection.
- After protection is enabled, the protected instance status changes to Synchronizing, indicating that differential data is being synchronized.
After protection is enabled, differential data is read from disks and synchronized to the disaster recovery site. During this period, the disk read bandwidth increases, and services may be affected, so you are advised to enable protection during off-peak hours.
