On this page
Show all
Help Center/ Situation Awareness/ User Guide/ Integrations/ Checking the Connection Status of an Integration
Updated on 2022-11-24 GMT+08:00
The connection status reflects the status of reporting detection data of other security products to SA. This function is used to check whether an integration can report data to SA.
Table 1 Connection status description
Status
Connected
The data API is called not less than 8 times within one hour. This means the API connectivity is normal, and the integration will properly report detection data to SA.
By default, the connection status of an integration is healthy within one hour after the integration is enabled.
Disconnected
The data API is called less than 8 times within one hour. This means the API connectivity is abnormal, and the integration cannot report detection data to SA.
Connection check stopped
The integration no longer reports detection data to SA.
Connection not checked
The integration never reports detection data to SA.
The connection status of an integration is determined by how many times the integration calls the data reporting API. An integration can call the data reporting API every 5 minutes to check the connectivity.
  2. Click in the upper left corner of the page and choose Security & Compliance > Situation Awareness > Integrations.
    Figure 1 Viewing heartbeat statuses of integrations
  3. In the connection status drop-down list, select a status. All integrations in the selected status will be displayed.
  4. In the panel for a specific integration, view the data volume received from and the connection status of the integration.
    Figure 2 Viewing data from other security products
