OBS
Updated on 2024-11-25 GMT+08:00
The OBS connector provides massive, secure, highly reliable, and low-cost object-based cloud storage capabilities via Huawei Cloud Object Storage Service (OBS).
Creating an OBS Connection
  1. Log in to the new ROMA Connect console.
  2. In the navigation pane on the left, choose Connector. On the page displayed, click New Connection.
  3. Select the OBS connector.
  4. In the dialog box displayed, configure the connector and click OK.
    Name
    Enter the connector instance name.
    App Key
    Access key ID (AK) of the current account. Obtain the AK by referring to Access Keys. If an AK/SK pair has been generated, find the downloaded AK/SK file (such as credentials.csv).
    App Secret
    Secret access key (SK) of the current account. Obtain the SK by referring to Access Keys. If an AK/SK pair has been generated, find the downloaded AK/SK file (such as credentials.csv).
    Enter the description of the connector to identify it.
Action
  • Downloading an object
  • Deleting an object
  • Listing buckets
  • Creating a bucket
  • Deleting a bucket
  • Obtaining bucket metadata
  • Listing objects in a bucket
  • Deleting objects in batches from a bucket
  • Uploading an object
Configuring Parameters
Table 1 Action parameters
Actions with the Parameter
Connection Type
Select a connection mode.
  • Region ID
  • Endpoint
All
Region ID
Select a region ID.
All
Endpoint
Endpoint
All
Bucket Name
OBS bucket name.
Downloading, deleting, or uploading an object, creating or deleting a bucket, obtaining bucket metadata, and deleting objects in batches from a bucket
Object Name
Enter an object name. Example: 123.png. Only TXT, CSV, PNG, JPG, and JPEG files are supported. Unlike file system, OBS does not have files or folders. The slash (/) in an object name simulates the folder path. Object name (key) of test/123.jpg is test/123.jpg. In this case, set this parameter to test/123.jpg.
Character Set
UTF-8 or GBK (for downloaded files containing Chinese characters)
Bucket Type
Specify the bucket type. Default: OBJECT
  • OBJECT
  • POXIS
Listing buckets
Bucket Location
Whether to query the bucket location.
Yes
No (default)
Listing buckets
Region
Where to create the bucket in. Mandatory unless the endpoint is obs.myhuaweicloud.com. Default for endpoint obs.myhuaweicloud.com without specified region: CN North-Beijing1 (cn-north-1).
Creating a bucket
CORS Origin
Origin (usually a domain name) specified by the cross-origin pre-request. Separate origins with line breaks. Each origin can contain one wildcard character (*) at most.
HTTP Request Header
HTTP headers in the cross-domain request. CORS requests must match the allowed headers.
Object Name Prefix
Objects to list must contain this prefix.
Start Position
Where the object listing begins, in lexicographical order.
Max.
The upper limit for objects in the response. Range: 1–1000. If the input value is greater than 1,000, only 1,000 objects are returned.
Delimiter
For grouping object names. If an object name contains the set delimiter, the string from the first character to the first delimiter in the object name (excluding any prefix) is taken as a group under commonPrefix.
Coding Type
Encoding method to apply to some elements in the response. For delimiter, marker, prefix, nextMarker, and key containing control characters not supported by the XML 1.0 standard, set encodingType to encode the response delimiter, marker, prefix (including the prefix in commonPrefixes), nextMarker, or key.
Response Mode
Response mode for deleting objects in batches.
No (default): The response includes the deletion result of each requested object.
Yes: The response includes only results of objects failed to be deleted.
Basic Type
Basic type of the object. Text (default): TXT or CSV. Image: PNG, JPG, or JPEG.
Uploading an object
Content
Mandatory for a text object. The system generates an object based on the content and object name.
Uploading an object
Base64 Code
Mandatory for a binary object. The system generates an object based on the Base64 code and object name.
Uploading an object
