Updated on 2024-11-25 GMT+08:00
The CodeArts Pipeline connector interconnects with Huawei Cloud CodeArts Pipeline.
CodeArts Pipeline allows you to visualize and customize pipelines to shorten the delivery period and improve quality.
You have subscribed to CodeArts Pipeline.
Creating a CodeArts Pipeline Connection
  1. Log in to the new ROMA Connect console.
  2. In the navigation pane on the left, choose Connector. On the page displayed, click New Connection.
  3. Select the CodeArts Pipeline connector.
  4. In the dialog box displayed, configure the connector and click OK.
Name
Enter the connector instance name.
Enter the description of the connector to identify it.
Access Key
Access key ID (AK) of the current account. Obtain the AK by referring to Access Keys. If an AK/SK pair has been generated, find the downloaded AK/SK file (such as credentials.csv).
Secret Access Key
Secret access key (SK) of the current account. Obtain the SK by referring to Access Keys. If an AK/SK pair has been generated, find the downloaded AK/SK file (such as credentials.csv).
Action
  • Obtaining the pipeline execution status of a project
  • Obtaining the pipeline status
  • Obtaining the pipeline list
  • Deleting a pipeline
  • Obtaining pipeline status in batches
  • Stopping a pipeline
  • Starting a pipeline
  • Checking the pipeline creation status
  • Querying template details
  • Querying the template list
Configuring Parameters
Table 1 Obtaining the pipeline execution status of a project
region_id
Region ID.
project_id
CodeArts project ID.
start_date
The start date is included in the query period. The interval between the start date and end date cannot exceed one month.
end_date
The end date is included in the query period. The interval between the start date and end date cannot exceed one month.
offset
Offset, which is the position where the query starts. The value must be no less than 0.
limit
Number of records of each query.
Table 2 Obtaining the pipeline status
pipeline_id
ID of the pipeline whose status is to be queried.
region_id
Region ID.
build_id
Run ID of the pipeline whose status is to be queried.
Table 3 Obtaining the pipeline list
region_id
Region ID.
pipeline_name
Pipeline name. If the parameter exists, fuzzy match is performed.
project_ids
CodeArts project IDs. If this parameter is specified, the pipeline list of the corresponding project is returned. Separated project IDs with commas (,). The number of IDs range from 0 to 10. If not, the pipeline list of the tenant to which the invoker belongs is returned.
creator_ids
Creator ID. Separated IDs with commas (,). The number of IDs range from 0 to 10.
executor_ids
Executor ID. Separated IDs with commas (,). The number of IDs range from 0 to 10.
status
Pipeline execution status. Value options: waiting, running, verifying, handling, suspending, and completed.
outcome
Pipeline result, which is used to mark the pipeline. Value options: error, success, aborted.
sort_key
Sorting field. Value options: pipeline_name, create_time, start_time.
sort_dir
Sorting type. asc: Ascending; desc: Descending.
git_url
Link format: git@codehub.XXX.git (CodeHub); git@gitee.com.XXX.git (Gitee); git@github.com.XXX.git (GitHub).
offset
Offset, which is the position where the query starts. Min.: 0 (default).
limit
Number of records of each query. Value range: 10 (default) to 50.
Table 4 Deleting a pipeline
pipeline_id
ID of the pipeline to be deleted.
region_id
Region ID.
Table 5 Obtaining pipeline status in batches
region_id
Region ID.
pipeline_ids
Pipeline IDs for status inquiry.
Table 6 Stopping a pipeline
pipeline_id
Pipeline ID.
region_id
Region ID.
build_id
Pipeline execution ID.
Table 7 Starting a pipeline
pipeline_id
Pipeline ID.
region_id
Region ID.
name
Name of the build parameter.
value
Value of the build parameter. Max. length: 8,192 characters.
Table 8 Checking the pipeline creation status
task_id
Instance ID.
region_id
Region ID.
Table 9 Querying template details
template_id
Template ID.
region_id
Region ID.
template_type
Template type.
source
API caller.
Table 10 Querying the template list
region_id
Region ID.
template_type
Template type.
is_build_in
Built-in template or not.
offset
limit
Number of items displayed per page.
name
Template name, which is fuzzily matched.
sort
Sorting field.
asc
Ascending order or not.
