Updated on 2024-11-25 GMT+08:00
The CodeArts Check connector interconnects with Huawei Cloud CodeArts Check.
CodeArts Check is an in-house code check service. It is distilled from Huawei's years of experience in automatic static check and enterprise-level applications. CodeArts Check provides rich check capabilities for code styles, common quality, and cyber security risks. Comprehensive quality reports and convenient bug handling help enterprises effectively control code quality and achieve success.
You have subscribed to CodeArts Check.
Creating a CodeArts Check Connection
  1. Log in to the new ROMA Connect console.
  2. In the navigation pane on the left, choose Connector. On the page displayed, click New Connection.
  3. Select the CodeArts Check connector.
  4. In the dialog box displayed, configure the connector and click OK.
Name
Enter the connector instance name.
Enter the description of the connector to identify it.
Access Key
Access key ID (AK) of the current account. Obtain the AK by referring to Access Keys. If an AK/SK pair has been generated, find the downloaded AK/SK file (such as credentials.csv).
Secret Access Key
Secret access key (SK) of the current account. Obtain the SK by referring to Access Keys. If an AK/SK pair has been generated, find the downloaded AK/SK file (such as credentials.csv).
Action
  • Modifying a task rule set
  • Configuring advanced settings for a task
  • Querying check failure logs
  • Shielding directories of a task.
  • Query advanced settings of a task
  • Creating a check task
  • Querying check parameters of a rule set
  • Configuring check parameters of a task
  • Setting a default rule set for each language in a project
  • Customizing a rule set
  • Querying the rule set list
  • Viewing the rule list of a rule set
  • Querying selected rule sets of a task
  • Deleting a custom rule set
  • Obtaining rules
  • Stopping a check task
  • Querying issue details statistics
  • Modifying the issue status
  • Querying the task status
  • Querying historical scan results
  • Querying issue summary
  • Querying the CMetrics issue summary
  • Querying the task list
  • Executing a check task
  • Deleting a check task
Configuring Parameters
For details about the parameters, see the API Reference of CodeArts Check.
