The CodeArts Artifact connector interconnects with Huawei Cloud CodeArts Artifact.
CodeArts Artifact is designed for software release and management. Its secure software repositories allow you to manage software packages and their metadata, download release packages, and release software, achieving continuous delivery.
You have subscribed to CodeArts Artifact.
Creating a CodeArts Artifact Connection
- Log in to the new ROMA Connect console.
- In the navigation pane on the left, choose Connector. On the page displayed, click New Connection.
- Select the CodeArts Artifact connector.
- In the dialog box displayed, configure the connector and click OK.
Parameter |
Description |
Name |
Enter the connector instance name. |
Description |
Enter the description of the connector to identify it. |
Access Key |
Access key ID (AK) of the current account. Obtain the AK by referring to Access Keys. If an AK/SK pair has been generated, find the downloaded AK/SK file (such as credentials.csv). |
Secret Access Key |
Secret access key (SK) of the current account. Obtain the SK by referring to Access Keys. If an AK/SK pair has been generated, find the downloaded AK/SK file (such as credentials.csv). |
Action
Listing file versions in a project
Configuring Parameters
Parameter |
Description |
project_id |
CodeArts project ID. |
region_id |
Region ID. |
file_name |
File name. Fuzzy search is supported. |
limit |
Number of items displayed per page. |
offset |
Offset, which is the position where the query starts. The value must be no less than 0. |
