Iterator
The iterator processor is used to process data cyclically. You can specify the number of iterations, conditions, or arrays.
Configuration Parameters
Parameter |
Description |
Criteria |
Specify the iteration criteria.
Count |
When Criteria is set to Repeat, configure the number of iterations. The default value is 3. A maximum of 100 iterations can be executed. Any access will trigger an error report. |
Condition |
When Criteria is set to Do While, configure the iteration conditions. When the conditions are met, a maximum of 100 iterations can be executed. Any access will trigger an error report. |
Array |
When Criteria is set to Foreach, configure the arrays to be iterated, which can be obtained from the preceding node. For details, see Referencing Variables. A maximum of 100 elements can be included in an array. Any access will trigger an error report. |
Output variables
Parameter |
Description |
payload |
Data that is traversed. |
Loop size |
Loop count. |
Loop index |
Index of the current loop, starting from 0. |
Start time |
Start time of node execution. |
End time |
End time of node execution. |
Execution time |
Node execution duration, in milliseconds. |
