Updated on 2024-11-25 GMT+08:00
The Image Recognition connector allows accurate image recognition via the Huawei Cloud Image Recognition service .
Huawei Cloud Image Recognition has been enabled.
Creating an Image Recognition Connection
  1. Log in to the new ROMA Connect console.
  2. In the navigation pane on the left, choose Connector. On the page displayed, click New Connection.
  3. Choose Huawei Cloud Services > Image Recognition
  4. In the dialog box displayed, configure the connector and click OK.
    Name
    Enter the connector instance name.
    Authenticated By
    Select an authentication mode for the connector.
    Access Key
    Mandatory when Authentication Mode is set to AK/SK.
    Access key ID (AK) of the current account. Obtain the AK by referring to Access Keys. If an AK/SK pair has been generated, find the downloaded AK/SK file (such as credentials.csv).
    Secret Access Key
    Secret access key (SK) of the current account. Obtain the SK by referring to Access Keys. If an AK/SK pair has been generated, find the downloaded AK/SK file (such as credentials.csv).
    Enter the description of the connector to identify it.
Action
  • Celebrity recognition: Identifying movie stars and internet celebrities in images.
  • Tag recognition: Identifying the name, category, and confidence of an object in an image.
Configuring Parameters
Table 1 Celebrity recognition
Region
Region where the Image Recognition service resides.
Project
Project to which the Image Recognition service belongs.
Obtain Image from
Method to obtain the image. Options are API form parameters, Base64 encoding, and URL path.
API form parameters
If Obtain Image from is set to API form parameters, the trigger of this task flow must be OpenAPI, and images must be uploaded using form parameters of the form-data type. Set this parameter to the name of the form parameters.
Base64 encoding
If Obtain Image from is set to Base64 encoding, set this parameter to the Base64-encoded character string of the image. The size cannot exceed 10 MB.
URL path
If Obtain Image from is set to URL path, set this parameter to the URL of the image.
The value can be:
  • HTTP/HTTPS URLs on the public network
  • Huawei Cloud OBS URLs. To use OBS data, authorization is required, including service authorization, temporary authorization, and anonymous public authorization. For details, see Configuring the Access Permission of OBS.
Confidence
Threshold (0 to 1) of the confidence score. Tags with a confidence score lower than the threshold will not be returned.
Tags
Maximum number of tags that can be returned. The default value is 30.
Tag Language
Language of the returned tags.
  • zh: Chinese
  • en: English
The default value is zh.
Table 2 Tag recognition
Region
Project
Obtain Image from
Method to obtain the image, including API form parameters, Base64 encoding, and URL path.
API form parameters
If Obtain Image from is set to API form parameters, the trigger of this task flow must be Open API, and images must be uploaded using form parameters of the form-data type. Set this parameter to the name of the form parameters.
Base64 encoding
URL path
The value can be:
Confidence
