Adding Public Configurations for Custom Backends
Global public configuration items, such as variables, passwords, and certificates, can be added for a custom backend. This lets you quickly reference the added configuration items in the JavaScript script of a function backend.
- Log in to the ROMA Connect console. In the navigation pane on the left, choose Resource. On the displayed page, click the instance to access its console.
- In the navigation pane on the left, choose API Connect > Custom Backends. On the Configurations tab, click Add Configuration.
- In the dialog box displayed, configure related information and click OK.
Table 1 Adding public backend configurations Parameter
Configuration Name
Enter a configuration name.
Integration Application
Select an integration application for the configuration item.
Configuration Type
Select a configuration type.
Options: Template variable, Password, Certificate
Configuration Value
Available for Configuration Type set to Template variable or Password.
Enter the template variable or password.
Confirm Value
Available for Configuration Type set to Password.
Enter the password again, which must be the same as the value of Configuration Value.
Certificate
Available for Configuration Type set to Certificate.
Enter the certificate in PEM format.
Open the PEM certificate file in the certificate to be uploaded in text, and copy the certificate content to Certificate.
Private Key
Enter the private key of the certificate in PEM format.
Open the KEY/PEM private key file in the certificate to be uploaded in text, and copy the private key to Private Key.
Password
Enter the password of the certificate private key.
Confirm Password
Enter the password of the certificate private key again, which must be the same as the value of Password.
Enter a description of the configuration item.
- Reference the configuration item in a backend function script.
