Appendix: API Error Codes
The following table lists the error codes returned when a user fails to call an API.
HTTP Status Code |
Error Code |
Description |
Solution |
404 |
APIC.0101 |
The API does not exist or has not been published in the environment. |
500 |
APIC.0103 |
The backend does not exist. |
Contact technical support. |
500 |
APIC.0104 |
The plug-ins do not exist. |
500 |
APIC.0105 |
The backend configurations do not exist. |
400 |
APIC.0106 |
Orchestration error. |
Check whether the frontend and backend parameters of the API are correct. |
400 |
APIC.0201 |
Bad request. |
Set valid request parameters. |
413 |
APIC.0201 |
Request entity too large. |
Reduce the size of the request body to less than 12 MB. |
414 |
APIC.0201 |
Request URI too large. |
Reduce the size of the URI to less than 32 KB. |
494 |
APIC.0201 |
Request headers too large. |
Reduce the size of request headers to ensure that the length of a single request header is less than 32 KB or the total length of all request headers is less than 128 KB. |
502 |
APIC.0202 |
Backend unavailable. |
Check whether the backend address configured for the API is accessible. |
504 |
APIC.0203 |
Backend timeout. |
Increase the timeout duration of the backend service or shorten the processing time. |
401 |
APIC.0301 |
Incorrect IAM authentication information. |
Check whether the token is correct. |
403 |
APIC.0302 |
The IAM user is not authorized to access the API. |
Check whether the user is restricted by a blacklist or whitelist. |
401 |
APIC.0303 |
Incorrect App authentication information. |
403 |
APIC.0304 |
The app is not authorized to access the API. |
Check whether the app has been authorized to access the API. |
401 |
APIC.0305 |
Incorrect authentication information. |
Check whether the authentication information is correct. |
403 |
APIC.0306 |
API access denied. |
Check whether you have been authorized to access the API. |
401 |
APIC.0307 |
The token must be updated. |
Update the token. |
429 |
APIC.0308 |
The throttling threshold has been reached. |
Wait until the request throttling period ends and access the API again, or change the request throttling threshold. |
403 |
APIC.0401 |
Unknown client IP address. |
403 |
APIC.0402 |
The IP address is not authorized to access the API. |
Check whether the IP address is restricted by a blacklist or whitelist. |
503 |
APIC.0404 |
Access to the backend IP address has been denied. |
Use an available IP address to access the backend service. |
403 |
APIC.0405 |
The app is not accessed from a trusted IP address. |
Check whether the IP address is restricted by the client access control policy. |
500 |
APIC.0601 |
Internal server error. |
400 |
APIC.0602 |
Bad request. |
Check whether the request is valid. |
500 |
APIC.0605 |
Backend domain name resolution failed. |
Check whether the domain name is correct and has been bound to a correct backend address. |
500 |
APIC.0606 |
Failed to load the API configurations. |
400 |
APIC.0607 |
The following protocol is supported: {xxx} |
Use HTTP or HTTPS to access the API. |
500 |
APIC.0608 |
Failed to obtain the admin token. |
500 |
APIC.0609 |
The VPC backend does not exist. |
502 |
APIC.0610 |
No backend available. |
Check whether all backends are available. |
500 |
APIC.0611 |
The backend port does not exist. |
500 |
APIC.0612 |
An API cannot call itself. |
Modify the backend configurations, and ensure that the number of layers the API is recursively called does not exceed 10. |
500 |
APIC.0705 |
Backend signature calculation failed. |
