On this page
Adding Public Configurations for Custom Backends
Updated on 2023-02-28 GMT+08:00
Overview
Global public configuration items, such as variables, passwords, and certificates, can be added for a custom backend. Besides, you can quickly reference the added configuration items in the JavaScript script of a function backend.
  1. Log in to the ROMA Connect console. On the Instances page, click View Console of an instance.
  2. In the navigation pane on the left, choose API Connect > Custom Backends. On the Configurations page, click Add Configuration.
  3. In the dialog box displayed, configure related information and click OK.
    Table 1 Public reference configurations
    Configuration Name
    Enter a configuration name.
    Integration Application
    Select the integration application to which the configuration belongs.
    Configuration Type
    Select a configuration type. The value can be Template variable, Password, or Certificate.
    Configuration Value
    This parameter is available only when Configuration Type is set to Template variable or Password.
    Enter the template variable or password.
    Confirm Value
    This parameter is available only when Configuration Type is set to Password.
    Enter the password again, which must be the same as the value of Configuration Value.
    Certificate
    This parameter is available only when Configuration Type is set to Certificate.
    Enter the certificate in PEM format.
    Private Key
    Enter the private key of the certificate in PEM format.
    Password
    Enter the password of the certificate private key.
    Confirm Password
    Enter the password of the certificate private key again, which must be the same as the value of Password.
    Enter a description of the configuration.
  4. Reference the configuration item in a backend function script.
    For a configuration item named example, the reference format of each type of configuration is as follows:
    • Template variable: #{example}
    • Password: CipherUtils.getPlainCipherText("example")
    • Certificate: CipherUtils.getPlainCertificate("example")
