HTTP Response Header Management Plug-in
Overview
An HTTP response header is a part of an API response. An HTTP response header management plug-in enables you to customize HTTP response headers that will be returned in an API response.
Restrictions
- The system response headers (such as x-apig-* and x-request-id) cannot be modified.
- The response headers for CORS cannot be modified.
Parameter Description
Parameter |
Description |
Name |
Response header name, which is case-insensitive and must be unique within a plug-in. |
Value |
Value of the response header. This parameter does not take effect and can be left blank if you set Action to Delete. |
Action |
Response header operation. You can override, append, delete, skip, or add the specified header.
Script Configuration Example
"response_headers": [
"name": "header1",
"value": "test",
"action": "append"
"name": "header2",
"value": "roma",
"action": "override"
