Using Plug-ins
Updated on 2022-12-05 GMT+08:00
Overview
ROMA Connect provides flexible extension capabilities for APIs through plug-ins.
  • Plug-ins are independent of APIs. A plug-in takes effect for an API only after they are bound to each other. When binding a plug-in to an API, you must specify an environment where the API has been published. The plug-in takes effect for the API only in the specified environment.
  • An API can be bound to only one plug-in of the same type in the same environment.
  • Plug-ins that have been bound to APIs cannot be deleted.
Creating a Plug-in
  1. Log in to the ROMA Connect console. On the Instances page, click View Console next to a specific instance.
  2. In the navigation pane on the left, choose API Connect > API Management. On the Plug-ins tab page, click Create Plug-in.
  3. In the Create Plug-in dialog box, configure the plug-in information.
    Table 1 Plug-in configuration
    Plug-in Name
    Name of the plug-in you want to create. It is recommended that you enter a name based on certain naming rules to facilitate identification and search.
    Plug-in Type
    Type of the plug-in, which determines the extension capabilities of the plug-in.
    • CORS: specifies preflight request headers and response headers and automatically creates preflight request APIs for cross-origin access.
    • Kafka Log Push: pushes detailed API call logs to Kafka.
    • HTTP Response Header Management: provides custom HTTP response headers and returns them in API responses.
    • Circuit Breaker: protects the system when performance issues occur on backend services.
    Plug-in Scope
    Specify the scope to view the plug-in.
    • Integration application: The plug-in belongs to an integration application. Only users who have the permission on the integration application can view and use the plug-in.
    • Global: All users can view and use the plug-in.
    Integration Application
    This parameter is mandatory only if Plug-in Scope is set to Integration application.
    Select the integration application to which the plug-in belongs. If none is available, click Create Integration Application on the right to create one.
    Enter the plug-in description.
    Plug-in Content
    Content of the plug-in, which can be configured in a form or using a script.
    The plug-in content varies depending on the plug-in type:
  4. Click OK.
    After a plug-in is created, perform the operations described in Binding a Plug-in to an API for the plug-in to take effect for the API.
  1. In the navigation pane on the left, choose API Connect > API Management. On the APIs tab page, click the name of the API to which the plug-in is to be bound. The API details page is displayed.
  2. On the Plug-ins tab page, click Bind.
  3. In the Bind Plug-in dialog box, set Environment and Plug-in Type, and select the plug-in to be bound.
    You can search for a plug-in by name.
  4. Click OK. The plug-in is bound to the API.
