Updated on 2025-07-22 GMT+08:00
Importing Integration Assets
Overview
You can use the asset import function to quickly import an integration asset package to the ROMA Connect instance.
  • You have obtained an integration asset package.
  • In asset migration scenarios, you have modified instance configuration parameters. For details, see 4.
  1. On the Instances page of the ROMA Connect console, click Import Asset in the upper right corner.
  2. In the Import Asset dialog box, select Append or Overwrite based on the site requirements.
    • In asset restoration scenarios, select Overwrite.
    • In asset migration scenarios, select Append.
  3. If you select Overwrite, set whether to override the environment configurations.
    • Override: The imported data source will overwrite the existing data source with the same name.
    • Not Override: The imported data source will not overwrite the existing data source with the same name.
  4. Enter a prefix.
    FDI tasks in the same instance must have different names. To import FDI tasks with same name, enter a prefix for each task before importing
  5. In the dialog box displayed, select a local asset file and import it.
  6. After the import is complete, click Close. You can view the imported assets in the instance.
