Overview
ROMA Connect allows you to export applications and tasks of an instance as an asset file and import an asset file to restore or migrate integration assets. For details on how to import and export assets, see Importing and Exporting Assets.
- Asset restoration: You can export integration assets from a ROMA Connect instance for data backup. In the event of a faulty instance or data loss, you can import the backup asset file to the instance for restoration.
You are advised to periodically export asset files (for example, on a monthly basis) for data backup and restoration.
- Asset migration: You can import an integration asset file that was exported from existing ROMA Connect instances into a new instance to quickly deploy and reuse existing integration assets.
Only integration asset data can be imported, excluding asset-related instance configuration data. After integration asset import, you need to reconfigure asset-related instance data.
Category |
Item |
Description |
Processing Method |
Public instance information |
Integration application secret |
The secrets of integration applications are non-asset data. |
After assets are imported, ROMA Connect automatically generates new secrets. Notify interworking service applications to update the secrets accordingly. |
Integration application authorization information |
The authorization information of integration applications is non-asset data. |
Reconfigure user authorization after assets are imported. |
Data integration |
Data source connection information |
Includes the addresses, accounts, and passwords, which are non-asset data. |
Configure connection information for the corresponding data sources after assets are imported. |
Service integration |
APIs that have not been published in the RELEASE environment |
Include APIs that have not been published and APIs that have been published in a non-RELEASE environment. These APIs are non-asset data. |
Re-create and publish APIs as required after assets are imported. |
Environment information of APIs |
Includes the independent domain names, environment variables, cloud server information of load balance channels, and non-default environments. This information is non-asset data. |
Reconfigure environment information after assets are imported. |
Control policy information of APIs |
Includes request throttling policies, access control policies, client access control policies, and client quota policies. This information is non-asset data. |
Reconfigure control policy information after assets are imported. |
Secret information of APIs |
Includes signature keys, client's AppCodes, and custom backends' configurations of the password or certificate type. This information is non-asset data. |
After asset import:
Blacklist and whitelist specific to API authorization |
The blacklist and whitelist specific to API authorization is non-asset data. |
Reconfigure blacklist and whitelist information after assets are imported. |
Device integration |
Device information |
The device information is non-asset data. |
Re-create devices after assets are imported. |
Device rule information |
The device rule information is non-asset data. |
Re-create device rules after assets are imported. |
Restoration/Migration Process
The following table describes the restoration/migration process of integration assets.
No. |
Operation |
Description |
1 |
Obtain an integration asset package and collect information about interconnection with peripheral systems (such as data sources, backend services, and service applications). |
2 |
Modify the security group and configuration parameters of the instance you want to restore or a new instance. |
3 |
Import the integration asset package to the instance you want to restore or a new instance. |
4 |
Modify the authorization configurations of integration applications. |
5 |
Modify the connection configuration of data sources. |
6 |
Modify the environment, control policy, secret, and blacklist/whitelist configurations of APIs. |
7 |
Create devices and rules in batches. |
8 |
Interconnect with peripheral systems and verify services. |
