Viewing Details of an Instance
Overview
After an instance is created, you can view and edit the instance configuration information on the console, including basic information, configuration parameters, and data dictionaries, as well as import and export assets.
Content |
Description |
Instance |
Basic information about the instance, including the instance name, instance ID, edition, description, availability zone, creation time, and enterprise project.
VPC |
VPC associated with the instance. You can click the VPC name to view the VPC configuration. |
Subnet |
Subnet associated with the instance. You can click the subnet name to view the subnet configuration. |
Security Group |
Select the security group to be associated with the instance. You can click the security group name to view the security group configuration or click Edit to bind a new one. |
Routes |
Private network segment. After a ROMA Connect instance is created, it can communicate with the VPC subnet segment specified during instance creation by default. If other private network segments need to communicate with the instance, you can configure routes by setting this parameter. |
Connections |
Number of instance resource connections. For details, see the conversion between resources and connections. |
Billing Information |
Billing mode of the instance. |
Message Storage Space |
Information about the MQS message storage space of the instance, including the storage class and space usage (percentage). |
MQS Information |
Basic MQS configuration information about an instance. Modify MQS Capacity Threshold Policy as required. |
Service Connection Address |
Connection addresses of the instance:
Click |
Public Access |
EIP bound to the instance.
Public Outbound Access |
Addresses used by FDI and APIC to access public network data or services. The addresses are automatically configured during instance creation. |
