On this page
Show all
Appendix: API Error Codes
Updated on 2022-09-02 GMT+08:00
The following table lists the error codes returned when a user fails to call an API.
Table 1 Error codes
HTTP Status Code
Error Code
Solution
404
APIC.0101
The API does not exist or has not been published in the environment.
  • Check whether the domain name, method, and path are consistent with those of the registered API.
  • Check whether the API is published. If the API is published in a non-production environment, check whether the X-Stage header in the request is the name of the environment.
500
APIC.0103
The backend does not exist.
Contact technical support.
500
APIC.0104
The plug-ins do not exist.
500
APIC.0105
The backend configurations do not exist.
400
APIC.0106
Orchestration error.
Check whether the frontend and backend parameters of the API are correct.
400
APIC.0201
Bad request.
Set valid request parameters.
413
APIC.0201
Request entity too large.
Reduce the size of the request body to less than 12 MB.
414
APIC.0201
Request URI too large.
Reduce the size of the URI to less than 32 KB.
494
APIC.0201
Request headers too large.
Reduce the size of request headers to ensure that the length of a single request header is less than 32 KB or the total length of all request headers is less than 128 KB.
502
APIC.0202
Backend unavailable.
Check whether the backend address configured for the API is accessible.
504
APIC.0203
Backend timeout.
Increase the timeout duration of the backend service or shorten the processing time.
401
APIC.0301
Incorrect IAM authentication information.
Check whether the token is correct.
403
APIC.0302
The IAM user is not authorized to access the API.
Check whether the user is restricted by a blacklist or whitelist.
401
APIC.0303
Incorrect App authentication information.
  • Check whether the request method, path, query parameters, and request body are consistent with those used for signature.
  • Check whether the client time is correct.
403
APIC.0304
The app is not authorized to access the API.
Check whether the app has been authorized to access the API.
401
APIC.0305
Incorrect authentication information.
Check whether the authentication information is correct.
403
APIC.0306
API access denied.
Check whether you have been authorized to access the API.
401
APIC.0307
The token must be updated.
Update the token.
429
APIC.0308
The throttling threshold has been reached.
Wait until the request throttling period ends and access the API again, or change the request throttling threshold.
403
APIC.0401
Unknown client IP address.
403
APIC.0402
The IP address is not authorized to access the API.
Check whether the IP address is restricted by a blacklist or whitelist.
503
APIC.0404
Access to the backend IP address has been denied.
Use an available IP address to access the backend service.
403
APIC.0405
The app is not accessed from a trusted IP address.
Check whether the IP address is restricted by the client access control policy.
500
APIC.0601
Internal server error.
400
APIC.0602
Bad request.
Check whether the request is valid.
500
APIC.0605
Backend domain name resolution failed.
Check whether the domain name is correct and has been bound to a correct backend address.
500
APIC.0606
Failed to load the API configurations.
400
APIC.0607
The following protocol is supported: {xxx}
Use HTTP or HTTPS to access the API.
500
APIC.0608
Failed to obtain the admin token.
500
APIC.0609
The VPC backend does not exist.
502
APIC.0610
No backend available.
Check whether all backends are available.
500
APIC.0611
The backend port does not exist.
500
APIC.0612
An API cannot call itself.
Modify the backend configurations, and ensure that the number of layers the API is recursively called does not exceed 10.
500
APIC.0705
Backend signature calculation failed.
