Updated on 2025-08-25 GMT+08:00
Deleting a Conformance Package
If you do not need a conformance package any longer, you can follow the procedure below to delete it.
  2. Click in the upper left corner of the page. Under Management & Governance, select Config.
  3. On the left navigation pane, choose Conformance Package.
  4. Locate a target package and click Delete in the Operation column.
  5. In the displayed dialog box, click OK.
    After a conformance package is deleted, the rules included are also automatically deleted from the list.
    Figure 1 Deleting conformance packages
