Viewing Conformance Packages and Compliance Data
You can view all conformance packages created and their details. You can also set search options to filter conformance packages.
- Log in to the Config console.
- On the left navigation pane, choose Conformance Package.
- View all the conformance packages created and their details, such as evaluation results, compliance scores, and status.
- Locate a target package and click the package name to go to the details page.
On the details page, view package basic information, configurations, rules included, and the evaluation result of each rule.
Locate a target rule and click the rule name to go to the details page. Non-compliant resources evaluated using the rule are displayed by default.
Figure 1 Viewing details of a conformance package
Table 1 Conformance package deployment states Value
State
CREATE_SUCCESSFUL
Deployed
A conformance package has been deployed.
CREATE_IN_PROGRESS
Deploying
A conformance package is being deployed.
CREATE_FAILED
Abnormal
A conformance package fails to be deployed.
DELETE_IN_PROGRESS
Deleting
A conformance package is being deleted.
DELETE_FAILED
Deletion failed
A conformance package fails to be deleted.
ROLLBACK_SUCCESSFUL
Rolled back
Some rules in a conformance package failed to be created and were rolled back, and created rules were deleted.
ROLLBACK_IN_PROGRESS
Rolling back
Some rules in a conformance package failed to be created and were rolled back, and created rules were being deleted.
ROLLBACK_FAILED
Rollback failed
Some rules in a conformance package failed to be created, and rollback also failed. You can access RFS to check out the reasons.
UPDATE_SUCCESSFUL
Updated
A conformance package is updated.
UPDATE_IN_PROGRESS
Updating
A conformance package is being updated.
UPDATE_FAILED
Update failed
A conformance package fails to be updated.
Helpful Links
