Overview
ResourceQL provides SQL-like functions, allowing you to flexibly query your cloud resources.
SELECT name, created, updated FROM resources WHERE region_id = 'regionid1'
The statement is case insensitive. SELECT COUNT(*) and select CoUnT(*) are the same. Use single quotation marks to represent the literal of a string.
The following table lists seven data types supported by ResourceQL. For the array type, [] is used to index a position, and the number starts from 1.
       Type Name  |
       Type  |
       Integer  |
       Int/Integer  |
       Float  |
       Float/Double  |
       Boolean  |
       Boolean  |
       Array  |
       Array  |
       String  |
       String  |
       Dictionary  |
       Object  |
       Timestamp  |
       Date  |
All your cloud resources are included in a table. The table name is fixed to resources. All your resources of the resource aggregator are included in a table named aggregator_resources. Each row of the table contains a data record, and the columns are described as follows:
       Parameter  |
       Type  |
       Description  |
       id  |
       String  |
       Specifies the resource ID.  |
       name  |
       String  |
       Specifies the resource name.  |
       provider  |
       String  |
       Specifies the cloud service name.  |
       type  |
       String  |
       Specifies the resource type.  |
       region_id  |
       String  |
       Specifies the region ID.  |
       project_id  |
       String  |
       Specifies the project ID.  |
       ep_id  |
       String  |
       Specifies the enterprise project ID.  |
       checksum  |
       String  |
       Specifies the resource checksum.  |
       created  |
       Date  |
       Specifies the time when the resource was created.  |
       updated  |
       Date  |
       Specifies the time when the resource was updated.  |
       provisioning_state  |
       String  |
       Specifies the result of an operation on resources.  |
       tag  |
       Array(Map<String,String>)  |
       Specifies the resource tag.  |
       properties  |
       Map<String,Object>  |
       Specifies the resource attribute details.  |
aggregator_resources contains domain_id that indicates the account ID. The type of a domain ID is a string.
provider and type represent a unique resource. For different resources, properties varies. For example, for an ECS, the provider and type are ecs and cloudservers, and the properties contains flavor. For a VPC, the provider and type are vpc and publicips, and the properties contains bandwidth.
You can obtain resource attributes that can be included in the properties element for each resource by accessing the Config console or calling the related API. For more details, see How Can I Obtain Resource Attributes Reported to Config?
properties supports nested queries. The following shows an example of how to query the addresses parameter under properties for the running ECS.
SELECT name, created, updated, properties.addresses FROM resources WHERE provider = 'ecs' AND type = 'cloudservers' AND properties.status = 'ACTIVE'
