Help Center/ Config/ User Guide/ Resource Compliance/ Built-In Policies/ Object Storage Service/ OBS Buckets Have Server-side Encryption Enabled
Updated on 2026-04-16 GMT+08:00
Rule Details
Table 1 Rule details
Rule Name
obs-bucket-server-side-encryption-enabled
Identifier
If an OBS bucket does not require server-side encryption, this bucket is non-compliant.
Tag
obs
Trigger Type
Configuration change
Filter Type
obs.buckets
Rule Parameters
None
Application Scenarios
To enhance data security and compliance, enable server-side encryption to ensure that data transmitted to OBS is encrypted. For details, see Server-Side Encryption.
Solution
You can configure a bucket policy to explicitly deny all PutObject requests where the condition key x-obs-server-side-encryption is not kms. For details, see Bucket Policy Condition.
The following is an example. Original bucket policy: {"Statement": [{"Sid": "test", "Effect": "Allow", "Principal": "*", "Action": ["*"], "Resource": ["testBucket/*"]}]}
Remediated bucket policy: {"Statement": [{"Sid": "test", "Effect": "Allow", "Principal": "*", "Action": ["*"], "Resource": ["testBucket/*"]}, {"Sid": "test_add", "Effect": "Deny", "Principal": "*", "Action": ["*"], "Resource": ["testBucket/*"], "Condition": {"StringNotEquals": {"x-obs-server-side-encryption": ["kms"]}}}]}
Rule Logic
  • If the OBS bucket policy explicitly denies all putObject requests where the condition key of x-obs-server-side-encryption is not kms, the bucket is compliant.
  • If the OBS bucket policy does not explicitly deny all putObject requests where the condition key of x-obs-server-side-encryption is not kms, the bucket is non-compliant.
