OBS Buckets Have Cross-Region Replication Enabled
Rule Details
Parameter |
Description |
Rule Name |
obs-bucket-replication-enabled |
Identifier |
Description |
If an OBS bucket does not have cross-region replication enabled, this bucket is non-compliant. |
Tag |
obs |
Trigger Type |
Configuration change |
Filter Type |
obs.buckets |
Rule Parameters |
None |
Application Scenarios
Cross-region replication enables cross-region DR, catering to your needs for remote backup. For details, see Cross-Region Replication.
Solution
OBS supports cross-region replication configuration using the console, APIs, and obsutil. For details, see Cross-Region Replication.
Rule Logic
- If an OBS bucket has cross-region replication enabled, this bucket is compliant.
- If an OBS bucket does not have cross-region replication enabled, this bucket is non-compliant.
