Multi-AZ Backup for CBR Vaults
Rule Details
Parameter |
Description |
Rule Name |
cbr-vault-multi-az-check |
Identifier |
Multi-AZ Backup for CBR Vaults |
Description |
If multi-AZ backup is not enabled for CBR vaults, the check result is non-compliant. |
Tag |
cbr |
Trigger Type |
Configuration change |
Filter Type |
cbr.vault |
Rule Parameters |
None |
Application Scenarios
Storing backup data in multiple AZs improves reliability.
Solution
View your backup vaults to check that multi-AZ backup is enabled for your vaults.
Rule Logic
- If multi-AZ backup is not enabled for CBR vaults, the check result is non-compliant.
- If multi-AZ backup is enabled for CBR vaults, the check result is compliant.
