GeminiDB Database Engine Version
Rule Details
Parameter |
Description |
Rule Name |
geminiDB-instance-engine-version-check |
Identifier |
GeminiDB Database Engine Version |
Description |
If the GeminiDB database engine is earlier than the specified version, the check result is non-compliant. |
Tag |
gemini db |
Trigger Type |
Configuration change |
Filter Type |
nosql.instances |
Rule Parameters |
specifiedVersion: required GeminiDB database engine version. For details, see Version Information. |
Application Scenarios
After a vulnerability is identified, the cloud service team fixes the vulnerability and releases a new version. You need to upgrade the version periodically to prevent vulnerabilities in earlier versions.
Solution
Upgrade the database engine by referring to the following guides:
- Upgrading a Minor Version of GeminiDB Redis
- Upgrading a Minor Version of GeminiDB Influx
- Upgrading a Minor Version of GeminiDB Cassandra
- Installing a Patch of GeminiDB Mongo
Rule Logic
- If a GeminiDB instance uses a version earlier than the specified version, this instance is non-compliant.
- If a GeminiDB instance uses the specified version or later, this instance is compliant.
