Updated on 2025-08-25 GMT+08:00
GaussDB Instance Port Check
Rule Details
Table 1 Rule details
Rule Name
gaussdb-instance-port-check
Identifier
If a GaussDB instance is using a disabled port, the check result is non-compliant.
Tag
gaussdb
Trigger Type
Configuration change
Filter Type
gaussdb.instance
Rule Parameters
blockedPorts: disabled GaussDB instance ports
Application Scenarios
The default port of GaussDB instances is 8000. The default port is easy to be listened, which poses security risks. You are advised to use a non-default port.
Rule Logic
  • If a GaussDB instance is using a disabled port, the check result is non-compliant.
  • If a GaussDB instance is not using any disabled port, the check result is compliant.
