Updated on 2025-08-25 GMT+08:00
DCS for Redis Instance Version
Rule Details
Table 1 Rule details
Rule Name
dcs-redis-engine-version-check
Identifier
If a DCS for Redis instance is earlier than the specified version, the check result is non-compliant.
Tag
dcs
Trigger Type
Configuration change
Filter Type
dcs.redis
Rule Parameters
engineVersion: DCS for Redis instance version
Application Scenarios
New updates often address security issues and add new features. Always use the most recent Redis version for better performance and safety. For details, see Comparing Redis Instance Types.
Solution
Currently, DCS does not support direct instance upgrades. You need to migrate data from the earlier instance to a later one. For details, see Upgrading a Redis 3.0 Instance.
Rule Logic
  • If a DCS for Redis instance is earlier than the specified version, the check result is non-compliant.
  • If a DCS for Redis instance is later than or equal to the specified version, the check result is compliant.
