Help Center/ Config/ User Guide/ Resource Compliance/ Built-In Policies/ API Gateway/ Dedicated API Gateway Deployed in Multiple AZs
Updated on 2025-08-25 GMT+08:00
Rule Details
Table 1 Rule details
Rule Name
apig-instances-multi-az-check
Identifier
If a dedicated API gateway instance is not deployed in multiple AZs, this instance is non-compliant.
Tag
apig
Trigger Type
Configuration change
Filter Type
apig.instances
Rule Parameters
None
Application Scenarios
To enhance gateway availability, deploy the gateway in multiple AZs. Otherwise, services will be unavailable if one AZ is faulty.
Solution
When creating a gateway, select multiple AZs.
Rule Logic
  • If a dedicated API gateway instance is not deployed in multiple AZs, this instance is non-compliant.
  • If a dedicated API gateway instance is deployed in across AZs, this instance is compliant.
